Has anyone got a oxydrive controller
Hozaythkid
29
My Oxydrive controller did the same on fully charged batteries it kept cutting out with the low voltage 06 error code so a component had failed inside. The batteries soldered on for a bit more using another controller.
It’s a shame how I can’t see any error codes due to the smashed screen but hopefully this new battery and lcd will get me back to riding I miss it so much
8,781
Might want to check the Yose battery actually has the integrated controller inside and not just an empty discharge case for the wiring seems a bit cheap to have controller as well. Description /legend doesn't suggest one is included.
Hozaythkid
29
Ah right ok I was thinking it’s a bit cheap so my best bet is to buy it all from woosh then
3,994
Y
yesss amazing idea if I can get more speed an power so a 48v battery will work fine with the 8fun motor then ? I will defo do that I’m in the U.K. but wouldn’t use full power on roads
I mean where exactly do you live? There might be someone who lives nearby that has what you need.
geezee74
68
Hi, morning sure info this thread is dead but I need help with my oxydrive battery. I have tried Andrew at oxydrive but no response. My battery is completely dead. I wondered if I could Get a new battery Andy casing as the casing is cracked.
I live in Market Harborough just in case anyone is near.
8,781
Oxydrive by H7 engineering no longer sell the kits so no longer any spares available.
