Hi
I have bought this conversion kit https://www.aliexpress.com/item/1005002026936921.html?spm=a2g0o.store_pc_groupList.8148356.1.6c1a80bfUV2NZ9.
My motor is 1500W 48V
Control box : KT48ZWSRL-CP06 ( Max current 35 +-2A, Rated Voltage 48VDC, Rated current 17A, Speed set 1-4.2V)
I have a KT-LCD3.
I tried to drive on it after i had assembled it but short after i have got an " 03 info " error code that means hall sensor signal abnormality.. What should i do?
I have tested for loose connections many times now..
I have heard about programming using the LCD - is there any chance that i could solve the problem if i tried to change some of those settings?
Thank you all in forward
I have a KT-LCD3.
