Front fork manual, I think I've found the correct manual here....
http://www.sram.com/_media/techdocs/95-4015-022-000 print.pdf
Hi Bonefishtone,i have noticed it has some writing on the bar top which reads 40-50lb,i suppose thats a torque setting and if so can you buy allen keys which have a torque guage or how do you know how tight to do them up?
Yes, this is normal. The seals do all they can but as with forklifts, motorcycles, etc the 'ram' will always have a thin film of oil on it for the dust to stick to.There is a film of oil around the front fork tubes and rear shock which dirt etc has now stuck to,would you think this just a normal running/bedding in issue?
Hi Bonefishtone,I still cant feel a lot of difference when i adjust the 2 knobs on the rear shock,the gold one which has "gate" stamped on it is pointing strait up,same with the blue one behind it,should they be adjusted as a pair?
Well I think James has answered most of your questions, however....I weigh 90Kg and I've upped my pressure to 260psi, I appear to like running it at higher pressures (or the shock does), and it puts me at 20% sag. As a precaution I would have thought that for your style of riding, you might be better off with higher then 190psi !!Thanks Tim for the shock info, i have now increased mine to 190PSi and re weighed myself at 90lbs so ready to ride (clothed) i must be closer to 115lbs.It seems to be useing 90% of its travel but i have chickened out of jumping over the flower bed wall for now,(its only about 20" high)so i still need to properly test it, its a easy jump on my dirt bike,just looks a little daunting for the forks frame on a pedelec,as not ever owning a mountain bike before i dont want to wreck it just yet,do you think its capable of that sort of drop or is it a must land on the rear,not the forks?
This is normal, the oil attracts dust and will be slowly be consumed by dust, requiring cleaning and renewing. If you read the manual or check the online maintenance articles they recommend that after a few hours of usage you should clean the tubes and re-apply a thin coat of [snake] oil to maintain good movement and keep the seals lubricated, last thing you want is poor stitchion. These shocks are air filled which, unlike oil filled motorcycle shocks, will not self lubricate, therefore maintenance is required.There is a film of oil around the front fork tubes and rear shock which dirt etc has now stuck to,would you think this just a normal running/bedding in issue?
Suspension setup beyond setting sag can be a specialised black art and is dependent on many factors including rider experience. My advice would be to leave these settings at mid-point and if it is OK then don't try and fix it. Whilst these suspension units will probably cost around £250 a piece to replace they are not considered high end, relatively speaking, and therefore offer a limited amount of adjustment for the average trail rider. If you were a pro, then you would pay lots more for a suspension setup to your exact liking and riding conditions that day and would have spent many hours (and ££££) in the saddle working it all out (just like motorbike riders do).I still cant feel a lot of difference when i adjust the 2 knobs on the rear shock,the gold one which has "gate" stamped on it is pointing strait up,same with the blue one behind it,should they be adjusted as a pair?
I believe James is looking into this.In the BOSCHE manual, page 28 it states the speed and distance indicators can be displayed in KPH or MPH,depending on country-specific versions, but we have obviously got the KPH version, i wonder if James is able to provide a MPH version for UK owners, and if a new HMI drive will just clip on or is each HMI only useable for the bike it was supplied with?
Yes, I noticed this, not sure I'd have the patience to try it, this bikes too much fun to be poodling around at 25kph in an efficient manner!!In case you had not read it Page 30 states a fully charged battery and a efficient riding manner that a opperating range of 145KM is possible!
There's a wide range of helmets to suit all conditions, budgets etc, best to speak to one or two LBS's and try some on.I have been giving it a right old bashing over the fields and have decided it may be a good idea to get a helmet, regular bike ones seem a little flimsy,but motorcycle ones,even the trial riders type a bit over the top,any sugestions of a good type/make or even a good internet store?
Hey, we all know car drivers are idiots, right? Plenty of advice on this forum about road riding, best stick to the trailsI rode down my lane at 47kph,it seems plenty fast enough but car drivers seem to think bikes (or me) are a must to over take,(in this village anyway) even in a 30mph limit, but i suppose you owners of pedelects have got used to it, i found it worrying,they probably found me annoying!
Hi Indalo, nothing new here regarding full suss, just trying to explain in a bit more detail which might be confusing for some. Certainly any new FS bike should be adjusted for riders preference and this includes the front and rear shocks, sag being the most important mainly to prevent damage to the suspension (and possibly only setting that should be set correctly).I don't know about other readers but having ploughed through all the postings so far in this thread, I think I've gone right off the xDuro model. The last thing I want if spending something north of 2 grand on a bike is to be spending lots of time making suspension adjustments.
It really depends on how you use the bikes, do you trail ride, all mountain, singletrack, XC, downhill, X4, jumps, North Shore ? Each one is a seperate, but related, mountain bike discipline and has a language all it's own. The Xduro is all mountain (an all-rounder for us laypeople). If you are only light trail riding you probably don't need rear suspension in the first place.As it happens, I have two identical full-sus mountain bikes and only ever tried once to alter the factory settings on one bike, keeping the other as supplied. After messing around with various settings, I found that the original settings were pretty much optimal for both me and my other half. They have never been adjusted since and continue to provide really good shock absorption and damping.
If you run your bike's hard off-road, they will need more maintenance and adjustment, a simple equation really. You really have to try one of these bikes to appreciate it's characteristics and why an electric motor is such a great idea. I know that this forum is not really orientated towards the slightly more advanced use of mountain bikes, but it is a pedelec. This is the first time a full suss, capable, electric mountain bike with crank drive has become available at a 'normal' price point in the UK, with dealer backup, discussion around it will help to understand it.Simplicity and low maintenance are, for me, far more desirable elements in a bike than the ultimate in suspension characteristics. Perhaps I'm missing something but I'm not altogether sure why electric assistance is desirable or worthwhile in an off-road styled bike. I'm sure someone can explain though.
Although I wouldn't compare it with your Haibike on all features, apart from the rear suspension type the Tonaro Bighit has the makings of one for the less well off who still want some similar enjoyment. It is very capable in the motor department, and with throttle control possibly more capable in some respects:This is the first time a full suss, capable, electric mountain bike with crank drive has become available at a 'normal' price point in the UK, with dealer backup, discussion around it will help to understand it.
Agree with that choice, less than half the price and looks to be capable of tackling most things, 90nm torque means it will fly up the hills. Would be interesting to see how the components hold up with a few months of hard use. Pity they couldn't have made it a bit more of a looker, but I'm sure that doesn't detract from it's functionality.Although I wouldn't compare it with your Haibike on all features, apart from the rear suspension type the Tonaro Bighit has the makings of one for the less well off who still want some similar enjoyment. It is very capable in the motor department, and with throttle control possibly more capable in some respects:
Tonaro Bighit
Indalgo you've made my night, thank you!Seems as though the substance doesn't quite measure up to the hype but perhaps I'm being unkind......no, hang on! This is advertised as a proper mountain bike, isn't it?
I really want to like this bike but the price is a deal-killer for me. When it then fails to demonstrate the robustness I would expect from such a machine, I'm put off completely.
Ok, we can say it's only to be expected that there will be a few teething problems with the Mk1 edition but when the sellers market the product as a premium machine with a commensurate price tag, it really ought to do what it says on the tin.
I'd bet that some of the members of this forum could produce a better machine for less money. I think the manufacturer should have got this launch right as it's been no secret for a long time now that it was coming.
Indalo
Thanks for your kind offer James but in the interest of objectivity and impartiality, perhaps you should direct your offer to flecc or one of the other forum contributors with more experience of different types of electric bikes. It might actually help your cause if you really believe the bike is all that it's cracked up to be.Indalgo you've made my night, thank you!
Shorting Accell was a mistake, you've just gotta take it on the chin and move on.
But seriously, where are you? maybe we can lend you one of these things for a day or so?
Rgds,
James
Chill Indalo, is there a thread somewhere that I've missed where you have got into an argument about the Bosch system or the Haibike in particular (or James) or is it just the price???Thanks for your kind offer James but in the interest of objectivity and impartiality, perhaps you should direct your offer to flecc or one of the other forum contributors with more experience of different types of electric bikes. It might actually help your cause if you really believe the bike is all that it's cracked up to be.
Regards,
Indalo
Or a ready built Tonaro Bighit for £1095 and have enough cash left over for a second one if it broke!It's a good challenge to see if anyone on here could build a bike capable of the same abuse......any takers? All you would need is a Heinzmann setup, hub motor and battery in the rucsac (cables everywhere) and a folding Paratrooperfor errr ahem, £2,500
