Haibike return policy
6,733
the yamaha bike has the old pw motor as the bosch with the cx drive says performance but it is a cx drive.
so 60nm than 75nm just turned down with software, and no this cant be changed.
Paying £500 for a replacement battery that has low internal resistance and works the same at 10% as 100%
That's utter rubbish! Who told you that?
The voltage is 42v when fully charged and about 34v at 10% charge. Ohms law says that current is proportional to voltage in any conductor. Power is volts x amps. No amount of sales ball cox can change the laws of physics.
6,733
just make sure you are happy with it size wise or you will regret it and tbh any bike shop that knows even the basics should of said a dropper post was a option.
LeighPing
2,547
1,945
The Red Ditch
I bought a 15" ebike which didn't quite fit my ape index, clickety, click. The bars felt too close, and a bit too low. So I tweaked it all with a new seatpost and an extending bar adjuster. It feels fine now. You may wish to do something similar to get your bike right for you and your mrs. Never mind all the inter-forum banter, you have a great bike. Enjoy it. :)
The whole family uses our two bikes. Me, the wife, my son, and my two daughters from time to time and, from 5'10" to 5'4", we all differ in height. I keep an Allen key multi-tool in the bike bag for easy 'on the fly' adjustments if we swap bikes around the local park.
We don't fanny around on our two bikes. That £10 ebay adjuster is 'solid'. :)
Reactions: IR772 and E-Wheels
nemesis
521
343
Bosch CX is the class leader at the moment,i have tried them all at their max perfotmance and what does it for me with the Bosch is the faster you go the better it performs against the others that seem to ramp down or tail off sooner with the power.
The impulse Kalkhoff motor was more powerful than the Bosch and i loved it but i had the 2015 version with the issues.
Reactions: LeighPing
D8ve
2,142
1,294
Bristol
It's a bit willy waving. Ether bike will make you a superman compared to unassisted bikes climbing, the woosh bikes will do that.
Then it's how much money vs a 1-2% difference in performance (if that)
Reactions: E-Wheels
IR772
931
1,044
Leominster
D8veh you would be correct if the motor were just directly connected to the battery and working flat out all the time, but it does not.
The Ebike has a controller which utilises PWM as we are using a % of assistance to the bike and not 100 %.
The controller will provide the same % output irrespective of the battery voltage as the software compromises for this reducing battery voltage.
Certainly this is what happens on my Haibike.
Just pointing out what really happens rather than ohms law.
Bodigidi
32
11
52
Somerset
Has anyone bought the SDuro hardseven 5.5? It's the same price as the XDuro 4.0 but has the bigger battery and according to the Haibike numbering system is a higher spec bike
IR772
931
1,044
Leominster
Its a Haibike what's not to like, also they finally used up all the garish colour paints they had hanging around (like mine) and it now looks great as well.
Bodigidi
32
11
52
Somerset
Well, I've collected my bike, and it's was the first time I have seen the XDuro in the flesh. I was expecting it to look the same as the SDuro, but with slight colour changes, but how wrong I was. The integration with the Bosch motor has been designed to perfection. The frame is nicely moulded to the battery, not just bolted on top. I'm well pleased.
With regards to the sizing, yes, I think for me the 50cm would have been better, but there is enough saddle adjustment to compensate. The 45cm also suits my daughter and wife better, so I think the whole family will be able to enjoy it.
Trevormonty
1,135
564
18
NZ
You will just have to buy another one for yourself so both wife and you can go for rides together.
