The new Haibike E MTB's have a neat motor protection shield mounted under the 2014 Bosch motor. Is this shield for sale as a spare part (to be mounted under a non-haibike)
Right; it is for the 2014 Performance motor and they are (and can not be) inverted.The new Bosch motors are not inverted, the new design makes it unnecessary.
In- or outside the motor?Mine is protected by a layer of mud, it has sound deadening properties too.
Only the outside, the Belgian Pavé shakes the other away.In- or outside the motor?
Sufficientwhats the clearnce on this bike?
To achieve sufficient clearance.and more importantly whats the actual point of mounting it above the downtube?
hmmmm, not overly helpful.Sufficient
thanks for that Martin, much more helpful.Hi Col,
The Gen1 Haibike has the motor mounted above the down tube, this gives maximum clearance and keeps the motor protected.
But that is off topic as the thread is about the Performance Motor mounted on the Gen2 Haibikes.
The simple answer is No. The haibike has a hinge built into the frame. This means the skid plate cannot be mounted onto other eBikes.
It's really neat actually, once the two bolts have been removed at the front it flaps down for easy access to the motor.
Regards
Martin
Col, why don't you visit Martins shop and try one for yourself. You can even take your tape measure with you.Thanks Martin...
Tim, you're still not really answering the question... but nevermind.
Martin, can you measure the bb axle to ground distance on a 29er hardtail with one of these systems, so we can compare. Because I can't see how you can put a tube under the motor, and not either decrease clearance, or raise the bb. I don't see how you can get 3" more clearance and not actually riase the height of the bb axle.
I'll have to have a better look at the geometry charts, because I'd not really considered this until reading these posts tonight.
Cheers
Col
