My finger is hovering over the reserve button as I have a 3rd mounting rail sitting in the garage, still have the HT Mtrax carbon frame so may build that up again as I also have enough components too. When I had the Oxy kit fitted it was too powerful and made the front end wheelie abit esp on hills offroad so GSM may well be better suited with CoG and weight placed centrally.using the same battery on two bikes? Nealh does just that. He's got two mounting rails for his 09 battery.
You can use the GSM 18A kit with any 36V battery.
Iif you get the 08 battery from bmsbattery, just ask them for a second mounting rail when ordering.
Thanks for the information. 50-60miles range would be amazing, but even if I only acheive half that it should be enough for me most of the time. I think I'm going to take plunge and get one of theseI rode the test bike with bmsbattery's 48V kit for about an hour. The bike ran faster and the motor got warmer but I did not notice anything wrong with the bike. Range wise: Woosh supply the kit with 36V 15AH battery and quoted 50-60 mile range (same as the woosh Krieger).
With that battery from bmsbattery, I guess you'd get about the same range. As you can ride very fast with a derestricted crank drive, the range you can get is mainly a function of speed and battery capacity. Allow 10WH per mile at 15mph, 20WH per mile at 20mph, 30WH per mile at 25mph. You get the idea.
And of course the effort you put into pedalling, I get about 5.75 Wh and average 16+ mph on the road or 3.75 Wh and 10 mph average in town.As you can ride very fast with a derestricted crank drive, the range you can get is mainly a function of speed and battery capacity. Allow 10WH per mile at 15mph, 20WH per mile at 20mph, 30WH per mile at 25mph. You get the idea.
Hydraulic brake sensors will be available also from December.OH ..forgot ..is there a sensor kit which allows use of any hydraulic brake system ?
