GoPro 7 Hero Black: Best low light night settings for video capture of number plates while cycling
3,346
It's difficult to tell from this video frame, but I've pointed the fork light (situated lowest) slightly to the right to better illuminate passing number plates at night... or that's the plan.
59560
59561
3,346
No problem recording plates going in the opposite direction, if they're close.
59562
59563
59564
3,346
Fast pass but not close. Basically this set of settings does the job great in daylight. Newer GoPros with more sensitive sensors, should perform even better.
59565
3,346
Because of high shutter speed darkening frames, and because I recorded during dark early morning, I've had to brighten up this very short and choppy compilation of blameless number plates, which you can pause to read at 1080P (selectable). Original overall video quality is higher due to higher data rate, but same resolution. You can see original quality still frame grabs posted above. I might add to this short compilation at some point, but editing is fiddly. My handlebar mounted Oxford lollipop prevents vehicles passing too close to my bicycle, so recording that continues to be impossible. I even angled it in a bit that morning. I've lengthened it a bit (said the Bishop to the actress)(the video). I might lengthen it again in future.
Reactions: Peter.Bridge
Peter.Bridge
1,586
728
I was just trying my <£30 Apeman A79 on my new bike on my lunchtime ride - I have it mounted on the handlebars with the usb cable plugged into my bike battery - I think the quality will be much inferior to the GoPro, but I tried reading a few number plates, both coming towards me and overtaking and using the "grab frame" they were all legible - don't think it would work in low light or dusk though - I might try it . I'm recording at 2.7k/30fps with electronic stabilisation on, there are some settings that I might have a play with.
Reactions: guerney
3,346
It's good for cyclists to have flight recorder options. Perhaps upload some videos and frame-grabs?
Night tests with the GoPro Hero 7 Black at 1/960s soon, but probably not on a lively Friday night.
3,346
this was on an overcast rainy day
Similar to my Crosstour Action 4K, which also did a decent job of recording plates in daylight, but was useless doing the same at night, hence my obsession - the GoPro Hero 7 Black does a decent job at night when plates are not too far away, at 1/480S. Video will look extremely dark at 1/960s. There won't be much viewable when played back on-camera, but I'm hoping post brightening will reveal all. I expect colour information will be scant.
I'm pretty sure my old Crosstour Action 4K could have been capable of recording number plates at night, if shutter speed was a user assignable setting... but no, functionality provided by the user interface copied the older GoPros.
ISO 100 is ok at 1/960s, which is the ISO the GoPro is set to automatically switch to for bright scenes, such as when pointed at the rising sun. The first part is ISO 800 when the scene was darker, the clues are car headlights and graininess. It was all underexposed, had to be brightend in post processing. Colours were lack lustre at such high shutter speed, hence boosted too much.
Frame grabs of innocent white car's plate which appears in the above video:
59608
59609
Another blameless BMW plate.
59617
Other, brighter frames from original video. Screengrabs using VLC, bear in mind my VLC is set to brighten a little.
59615
59616
3,346
Quite honestly, if I didn't do any dark cycling (sounds like something Aleister Crowley got up to lol), I would have stuck with my old cheap and cheerful £40 Crosstour Action 4K. But as night falls, a more customisable camera was required - nuts that I had to pay (at the time) £155 more plus new batteries, to get control over shutter speed!
3,346
With the settings in this post...
https://www.pedelecs.co.uk/forum/threads/gopro-7-hero-black-best-low-light-night-settings-for-video-capture-of-number-plates-while-cycling.44739/post-723410
...I've yet to cycle in the deepest inky dread blackness of night, but this was shot at 6.35am this morning, before the 6.49am sunrise... therefore I've had to brighten the video up rather a lot. Not at all a close fast pass, or a particularly close cutting in front after overtake before a traffic island.
Underexposed original frame grab from video, settings as above - looked brighter than this to the naked eye:
59846
Three frames brightened:
59847
59848
59849
...the above frame enlarged:
59850
Brightened dark grainy video, further crappified by Youtube compression. I would use higher quality Vimeo, if they didn't want my money.
3,346
Sorry, drivers continue to be repulsed by my lollipop, even in the dead of night. Here's a fast pass, not close. Swearing was emitted by one of the tipsy pedestrians waiting to cross.
Had to brighten a lot:
Here is the original underexposed video frame grab:
59874
Brightened:
59875
Enlarged:
59876
59877
This plate would have been clear if closer, and grainier at ISO1600. I'll stick with max ISO at 800, WITH 1/960s shutter speed when shooting day or night, and everything in between.
3,346
Such digital cameras will continue to improve, I do hope someone will post about one suitable for cyclist use, which does the job better in the same conditions, without costing a fortune.
@rsscott: I don't know what anyone else thinks, but I reckon making posts editable forever would be a good change, like Endless Sphere. I've noticed old posts on this forum with informative media hosted elsewhere disappears over time: Dropbox, Photobucket, Windows Live, iCloud, Google Drive, Facebook, Myspace etc. and it'd be better if posts could be updated by the authors to maintain maximum usefulness for site vistors. One reason why I've been linking to my Vimeo videos, is because they can be replaced in situ, unlike Youtube, therefore if I haven't much time I can do a rough edit (let's face it, all vids I upload here aren't neat) to upload to Vimeo and infinitesimally improve to make less dull later, without having to to attempt editing the uneditable post after the 24 hours pedelecs.co.uk deadline and failing. It was a race against time to replace the Youtube video above before the 24 hour timeout. Other videos I've posted on this thread can't be updated.
rsscott
Administrator
Staff member
Aug 17, 2006
1,399
196
We'll have a look at this when we move the site over to a new platform. We were hoping this would've been completed by now but we are waiting for a major update to be released.
Reactions: guerney
3,346
What's wrong with this platform? I like it. I say if it aint broke, don't fix it. There were initial teething troubles when the hosting changed, and @flecc mentioned a lot of old but interesting content was removed during the process. Will all that happen again? Live links are an important ranking measure. If links are forever updateable on old threads, they'd boost the forum's visibility on search engines; become a valuable source for traffic. It's important on a forum like this for links posted on old threads about pedelec law to be updatedeable forever. Also if someone has uploaded a photo revealing the GPS co-ordinates by mistake, potentially revealing their identity, they could remove it. Or if they have breached libel or copyright/other law accidentally - forum members being able to remove that stuff themselves, would mean less work for admins, and less potential financial liability for forum owners too, as platform/publisher laws change in future.
3,346
I was mucking about with a car dashcam in a home made chest harness and the dashcam gets its gps antenna connection from the car mount which if course was not there - hence the 2014 date at the bottom. it was last year at the end of August.
Your dash cam - this one?
...has done a good job of recording the passing plate at 3m 28s. Like many older dashcams and action cameras, fast shutter instead of aiming for a "Cinematic" look. If shutter speed and ISO can be set manually, it might manage the same trick at night sometimes? Doesn't look waterproof, for bike use.
3,346
BTW Here's how the GoPro 7 Hero Black does at night on full auto (old vid), minus stabilisation - had to switch that off because night footage is too blurry for "Hypersmooth" to function. Useless for number plate recording without manual settings. Normally brighter ahead, but one of my three lights was pointed downwards, loosened by a pothole.
60560
3,346
