I have just uploaded 4 YT videos all in 720p HD. The first one is a quick look round the test set up for my GNG Mid Drive. It still needs the controller and wiring repositioning and boxing up.
[video=youtube;vdHFhpNv5mU]http://www.youtube.com/watch?v=vdHFhpNv5mU&feature=player_detailpage[/video]
The controller I am using is not the 48V supplied with the kit, but a 36V CON91 from GreenBikeKit, I modified it with a direct connection for the Cycle Analyst. The battery is 12s A123 7Ah.
I have replaced the 38T chainring that came on the kit with a 44T, and have an 18T sprocket on the Nuvinc N360 Hub. But I think I may try a 16T as I feel that with the motor and pedal power the gearing is too low even on steep uphill climbs. The Nuvinci hub is smooth but not easy to vary up under high load. It certainly is easy to use and less chance of braking chains compared with clunky derailleurs.
The bike is a much modified Python Venom 180 DD complete with new forks, rear shock, wheels, Avid BB7 brakes and a KS adjustable seatpost. In fact it’s almost just the frame that is original.
The bike is a bit weighty with the motor, N360 and all the other accessories, at 25Kg. It does give a smooth ride even on the muddy bumpy tracks. I will however have to put some better tyres on as the back wheel has skidded sideways under hard braking on more than one occasion.
In the second video I have made a comparison with one of my other bikes, a light weight Full Suspension setup at 20Kg, powered by the BPM Hub.
I had to put the url link here as only 1 embeded video per post
Comparison rides - YouTube
I used the same camera, a Veho muvi HD10 at 720p the camera is in the waterproof case attached to the frames of each bike which seems to amplify the sound of the motors.
This 3rd video is an attempt to show the noise level of the motor with the camera off the bike. Unfortunately I picked a spot next to a streamlet which I barely noticed when I set up the camera. Also I think I moved the camera after I framed the shot so the track is a bit off to the side. But it still demonstrates, that what on the bike, appears to be a swarm of angry bees is almost inaudible with the camera a few feet away.
GNG ride past cut - YouTube
This last video was taken after riding a mile or so, and shows the reason for the siren I referred to in the previous video.
crash - YouTube
Chris
