http://ebike.ca
go to tools, ebike simulator, select the motor, click simulate.
This tool does not work with crank drive, for crank drives, there is a chart on the Woosh website
http://www.wooshbikes.co.uk/?motorcharts
The best known motor is the Ezee.
Maximum torque is about 50-80NM - at the wheel. That's the big difference. If you have the same torque at the chainring, the torque at the wheel will be 50NM * number of teeth on rear cog / number of teeth on chainring. The rear cog is usually smaller than the chainring, typically you have 30-40NM at the rear wheel with a Bosch motor. This is why the Ezee motor is the benchmark motor on e-bikes. The BPM is a little less powerful than the Ezee motor but still gives around 40-65NM at the wheel. Both Ezee and BPM are about a third more powerful than the Bosch Performance.
While you can climb 15% hills while pedalling backward on the Ezee and BPM, you can't do such a thing on the Bosch. These Ezee/BPM bikes consume about 13WH/mile but do not require riders' input.
The Bosch system relies on rider's input.
On eco settings, the rider supplies 70%, the motor 30%, at 20kph, the motor consumes 5.4WH/mile.
On turbo setting, the rider supplies 25% the motor 75%, the motor consumes about 10WH/mile at 25kph.
Bosch bikes suit strong pedallers. Ezee/BPM suit lazy pedallers.
