Gears, How Many is Too Many?
indalo
Banned
Sep 13, 2009
1,380
Herts & Spain
To get back on track, I have the now seemingly ubiquitous Nexus 8 on one bike and 27 gear Shimano on another. On the former, I probably use 5 through 8, 90% of the time occasionally bringing 4 into play on the steep bits. On rare occasions, I have utilised 2 & 3 on hill starts on really serious slopes.
27 gears is way too many for an ebike in my opinion as I manage pretty well on about half a dozen of them and I'm hardly an olympic athlete. When I ride unpowered, I may use a few more but that's it for me. I have sometimes wondered how many gears those lycra-clad road warriors actually use in their 50 mile Sunday appetisers. I know one who only uses one gear as he rides a 7 Kg single-speeder.....plus the weight of his handlebar-mounted sat-nav!
For leisure/utility cyclists, I think the Nexus/Alfine hubs are about as good as it gets but the 3-speed hub gear is probably sufficient for most eventualities.
Indalo
laroche
30
In a half-baked attempt to combine gears and politics, does anyone know why we put gears on the right, rather than the left?
30,846
Since the safety bicycle was invented in Britain, I'd guess it was because it was the side away from the pavement, for safety reasons.
Mussels
3,207
Crowborough
Back on the topic of gears....
I find that range is more important than the number of gears. The 300% range I have now is just enough (when the motor is in use), this isn't possible with derailleurs unless you have a front mech and that's unusual on an electric bike.
As well as the gear range the steps shouldn't be too big between the gears, my Alfine 8 suffers this problem and would be better with them closer. Shimano try to minimise the problem by having increasing the steps as it goes up the gears and it works pretty well but is still a compromise.
In short reduced gears may be OK for some areas but I found a 7 speed freewheel wasn't good enough, the 8 speed hub is adequate but more gears and range is desirable with or without the motor running.
Jimod
1,065
634
Polmont
Anyway - back to gears...
I've been finding I don't really need more than 3 - with the big front ring on; the smallest rear, an intermediate, and the largest rear do nicely. I'm not using the bike for mountain tracks as it was originally designed for, so those three gears are more than adequate, especially with the leccy hub.
Do you live in a hilly area? I guess the number of gears needed depends on where you live. Me, I need them all. In my area 9th would be too high for any of the hills, middle gear would be too high or too low depending on which hill and 1st would be too low for all the hills I've met except one. To be fair, I was tired when I got to the 1st gear hill.
Scimitar
1,772
40
Small slopes, but nothing much; the kind you notice without assistance, but even so aren't too bad. Of course, there are much bigger hills not so far away, but they can stay there :) My regular shopping/pottering routes don't involve much climbing at all. I've done with messing for gears for the moment, but might get back into it again, as I could do with an 11T smallest at the rear. Unfortunately, the largest ring I could fit at the front meant the front changer couldn't stay there and chain jump-offs became too frequent.
Pedalo
443
In case anyone cares, 6 widely spaced gears is plenty! :)
Jimod
1,065
634
Polmont
That is typical of Thatcherite economics. 6 gears will ruin cycling for decades. 9 gears is the minimum for proper cycling growth. ;)
jerrysimon
3,292
112
Cambridge, UK
Russ sorry about us rebels and thanks for all your efforts to help make this forum a great/very addictive place to come :)
Not sure if this post should be in this thread or the other :p
Regards
Jerry
laroche
30
Here's a neat bit of software which calculates all sorts of gear-related things. It's free.
Cycling Software
The download link is 'Download GearCalc Pro 2.2.16' on the first line of text.
Cheers!
