You just could not resistAgree entirely, The Neo does not have a large battery though.........along with the cheap components and high price I really don't get it.
May be you should try one
Of course if you had an electric car you wouldn’t need a gearbox. Luckily the torque characteristics of an electric motor are very well suited to vehicle propulsion, hence their popularity in larger vehicles not dependant on batteries, by enabling the elimination of the gearbox or torque converter.I think it's only fair to point out that the Neo needs a big motor because the motor is stuck in a single gear. For instance, my car would need a big thirsty engine if I only had 5th gear available.
I'm not sure that the Neo needs a big motor, but it's a fact that it has one, and you're right that if you use the full power, the battery will be used up more quickly; however, it also has a panel where you can turn the power down, so if you wanted to go the same speed as any other bike, it'll use approximately the same power depending on exact conditions.I think it's only fair to point out that the Neo needs a big motor because the motor is stuck in a single gear. For instance, my car would need a big thirsty engine if I only had 5th gear available. It's a brute force approach. I'm not knocking it, the brute force approach coupled with a big battery to feed the power hungry motor might suit some people, others may prefer their motor to take advantage of the bike's gears, get used to the quirks, and achieve the benefits associated with this type of arrangement.
Pot kettle black?You just could not resist
Hi
Quote removed from banned account
Worth noting that any ebike that exceeds the assist speed or power of either set of regulations, cannot be ridden anywhere in the UK except on private land that is not accessible to the general public. If an ebike is ridden on trails, byeways, parks or whatever then it has to comply with one or other set of regulations, either SI 1168 or EN15194, at all times to remain legal.It doesn't half go when you press it too. (off road only off course!) We sell the Mountain Sport too and love it!
