Furo X Battery Question
8,781
Half way there then, just needs a battery or another fiido battery rail to install on the furo if the bikes aren't going to be ridden in group ride.
8,781
So fiidos connections are exactly the same, but whilst connecting up, black first then red and spark. Papped myself
The sparks are normal esp as the controllers main capacitor would have been drained .
Reactions: ben619
ben619
33
Trying to find something which can be manipulated to fit the stupid oval shape seat post!
8,781
What do you think to this battery?
It's is the same case battery as the one I linked to from UPP also it is a yose battery which is on the the yose page. 20a continuous discharge with China branded cells it should be ok for the price, most likely it is also made by UPP with just with a customer brand name on the case.
8,781
The UPP one Iinked to in #8 shows the bracket fixing, doe sit look like it may fit ?
8,781
A pic of the seat post with the battery holder removed ?
ben619
33
I do like the look of the one you posted in #8, my only issue is that it doesn’t have the correct connections on, although I do have the crimps needed so don’t know why I’m making this a negative :p
please find attached pic!
8,781
As I thought, it has tapped fixings and a flat section. Can one not make use of the tapped holes to fix the new battery mount .
The one in #8 is the same as the yose power one, it just shows the seat post clamp better.
Find a bit of 5/6mmmm ali plate the dimensions of the furo battery base and drill two or three holes in it to match the frame tapped hole spacings.
On the new battery remove the metal clamp and fix the battery receiver (using the same clamp fixing holes) in between the frame fixing holes on the ali plate then simply a fix the plate to the seat post for the battery to securely sit on and lock into place.
The battery receiver fixings to the ali plate will need recessing a little on the rear so the heads are flush or just under the surface.
ben619
33
I like your style! I didn’t think of that, I wonder if I will have issues receiving it as it’s coming from Germany?
ben619
33
Good evening NeilH! I dont suppose i could borrow your brain again please!
Say i could get a 36v 20AH battery... Would that be ok to use with it? Or do i need to stick to around 10AH? Also, do you have posts for your bikes that are in your sig? They sound cool!
8,781
One can use any AH battery of the required voltage needed, AH only increases the bikes range and will usually make the battery heavier.
8,781
8,781
The Arkose with the Revos friction drive, bike is current and working.
The Vachery at Chelwood Gate. the background is a folly of the bridge to know where.
46299
This is at Ardingly reservoir. Apart from adding the 2.5kg ekit the only other mods I did was add a 42/11t cassette and add a wolf link to the derailleur hanger.
46300
8,781
There should be no issue.
8,781
The Walsall and Yose are the same branded one so buy either of them.
The UPP one is also the same battery but with differing branding, the other two are cheaper.
Reactions: ben619
ben619
33
Have contacted the Yose seatpost (vertical) battery supplier in walsall, i have seen they sold a few during this month for £116 so to see if they can offer me a similar price, you never know!
8,781
Another good ending, good job.
That's the beauty of ebikes with generic china electrics, easy peasy to sort out for quite cheap money.
Reactions: ben619
104bill
Dec 5, 2024
I have a furox ebike. but the controller has gone P-tong, need to find a replacement. any idea's
