Here's how I'd do it:Yes that's the pic I was thinking of d8veh, my problem will be that both my caliper & fork mounts are post mount where yours is an IS caliper, having to use an adapter gave a convenient mounting point. Seems like all you can buy now are post mount brakes that come with an adapter to fit IS forks which makes it a bit more tricky. Comparing my fork to yours the axle sits below the line of the fork lowers where mine is tucked up in line (right pain) reducing clearances.....looks like I didn't buy the best fork for converting but it's very difficult to see the issues unless you're working on it.
@ John , yes that's a good idea I hadn't thought of, probably get some of those & another adapter to see what I can rig up.
This pic gives a better idea of the issue.
Get or cut a piece of steel (pref. stainless) plate about 2mm thick to a size of about 80mm x 10mm;
drill a 6mm hole in one end;
Twist it through 90 degrees as tight as you can about 15mm from the hole end;
Mount it on the bottom post so that the main length hangs downwards (up if the bike's upside-down);
Fix the main part of the torque arm onto the axle and tighten the wheeel-nut;
Bend the piece of steel down until it covers the hole in the torque arm;
Mark and drill it the same size as the torque arm;
Fix it with a small nut and screw;
Trim the end with a dremmel or whatever.
Iit will then act as a tie bar. It's in tension so doesn't need to be too thick. It's imprtant to get the tension as high as possible, so push the torque arm back while you tighten the nut.
The photo seems to show it OK, but just in case: Make sure that the first washer fits in the dimple without riding up the side, otherwise the drop-out will pop off when you tighten the nut.
