The first setting that you used was the correct one.
I think now we can assume that your battery is OK. Normally, if it were weak, it would cut out prematurely.
The controller controls speed of the motor, not power, although it has a power algorithm in it that adjusts power to try to reach the speed set, so the next thing you need to determine is whether the motor can reach its maximum speed. If it can achieve 15 mph or more, then the throttle's working properly and the controller's probably giving its maximum power. If on the other hand its top speed is less than 15mph, then something is wrong with a setting on your panel or the controller.
To measure the speed, you need a cycle computer, or you need to be able to count very fast. 15mph is approx 200rpm.
Fix a cable tie to a spoke so that it clicks on the forks as it goes past. Make a line of ten pebbles, nuts or whatever. Lift the wheel; open the throttle; let it get up to speed; start a stopwatch and count the clicks. Every time you get to 20 push a pebble forward. When all 10 pebbles are moved, look at the stop-watch. If less than a minute, you have more than 15mph.
If you already have a cycle computer, temporarily fix the magnet on the back wheel. Unclip the sensor and display from the handlebar. Hold the sensor in the right position to get a reading from the magnet and spin up the motor to measure the speed. It takes a bit of practice to get it right. Rest your hand on the frame to hold it steadily in position.
Both these two procedures are easier with another person to help.
