Freego Electric Bikes
wheeliepete
2,047
757
Devon
If you don't have any luck with Freego admin., I have a working controller from an earlier Eagle, 2011, model no. not the same as yours, but maybe suitable. Check out if the connectors/wiring are anything like yours.
wheeliepete
2,047
757
Devon
The one with the four wire motor plug that goes to the motor the other only has three
Not sure what you mean? 8 wires go to the motor, 3 thick wires, yellow, blue and green and 5 thin wires, yellow, blue, green, black and red on the 5 pin connector. Thick red and black to battery.
Peter Twohey
16
-1
68
Petersfield Hampshire
Not an after market one but like most even Luishi they are only OEM supplied ususally.
The controller is made by Nanjing Yuanlang electronic.
In the case of needing to change the electronics then you will likely only need to swap out controller and lcd if used, motor wheel should/will work with any controller. The motor pin connector is/should be a standard 3 or 9 pin julet which all hubs use.
If you have analogue LED then you only need change controller, identifying wire connections should be easy on your set up so just a case of connecting a new controller like for like. Wire connectors may need changing so some soldering/crimping will be required. Most common easily sourced controller is the Kuenteng range (KT).
In the event that you end up down this route post a pic of your controller wiring.
8,616
Hi Pete no luck with that controller its to big and can't get any ignition but thanks got a new one coming take care
Where did you get one from was it via the Administrator ?
djbob
56
I bought a Freego eagle bike 6 months ago and the firm has gone bust I need a motor controller yurn lang model no yp-10-385(1) looks like I will have to replace the electrics and rear26inch wheel it is a twist and go any ideas?
yes plenty on ebay and amazon
