Folder recommendations
Bogmonster666
343
176
I’m after a budget folder. Must be able to cope with at least 14% gradient hills and must have disc brakes (certainly at the front). Would prefer torque sensor. Quite happy to put a fair amount of effort in myself. It’s for transport and I’m a busy person so want to get from a to b with moderate speed. I have a TSDZ2 powered mountain bike conversion that is great but it does not fold. The roads around here are rough and potholed but I’m not especially heavy. Because i don’t drive i want the flexibility of a bike i can stuff in friend’s boots or in a push put in a bag and take on a bus. I have a Tern but i don’t think it’s a good donor option due to frame problems. Would consider a steel Dahon but not sure about disc variants with steel frames. A hub folder isn’t my preferred option but as Ii have the mountain bike for longer rides it may be ok. Woosh Rambaletta with a torque sensor BB might work if Woosh sells such a thing?
Bogmonster666
343
176
I'm back on the folder hunt again after the death of my TSDZ2 - that should get fixed next week I hope but I need another bike as a spare anyway. A hub motor probably does make more sense and the correct motor in a 20 inch wheel will still provide a lot of hill climbing potential.
I like the TSDZ2 but the reliability is a downer and its particularly prone to water ingress - and it's not always possible to plan your life around the UK weather.
Moving my TSDZ2 to a folder is still an option and although a small chainring would make for slower progress it's not terrible. My current bike has 26" wheels and a dual 34t, 42t chainrings. A 46t chainring in 20" wheels is exactly the same ratio as the 34t on 20" wheels and that gets me up to ~18+ mph comfortably. On a folder for short rides that's fine. Wouldn't be suitable for main bike as I'm often travelling at well over 20mph (and that's just using legs before anyone asks).
I guess if I go down that route, would then be in the market for a replacement main bike, again though, needs to cope with 16% hills. That's certainly at the upper end for many hub motors in normal sized wheels. Not sure if a Gran Camino would cope and that's towards the top of what I want to spend.
Tbh, I am tempted to just try and get fitter and get a bike with adequate gear range and use my legs. I have cycled up said hill under my own steam, but it requires careful pacing with my feeble lungs. .
Peter.Bridge
1,583
727
You don't need a folder to go up 16% hills if that is your only reason for getting one. I have an ancient Carrera Vulcan with 26" wheels and road tyres with the very commonplace 48v Bafang G020 rear hub kit. (E.g https://www.ebay.co.uk/itm/394203165631?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=gcuwhq0ktpi&sssrc=4429486&ssuid=e7wJGK-DRD6&var=662716740592&widget_ver=artemis&media=COPY)
Max no load speed is around 45km/h and the advertised max unresticted speed is 40km/h (easily achievable). It came with an 18 amp speed based controller but I changed to the Woosh 15 amp power based controller with torque sensor. I am 105 kg and get up here (one of my regular rides)with a bit of peddling effort :
Eta
Woosh do a DWG22C 48V 60NM rear hub kit which will be an even better hill climber (heavier motor, lower no load speed)
Peter.Bridge
1,583
727
I wondered about this as a donor folding bike with disc brakes
Aluminium Frame with hi tensile forks :
Not sure about rear hub conversion, others here would better advise, steel front forks would probably be ok for front hub conversion
3,344
It does appear there are not many steel framed 20" wheeled folding bikes with disc brakes out there, but here's one. Even if this apparently German shop is real, they might not ship to the UK, and I don't know anything about the "Compass" brand.
Bogmonster666
343
176
The reason for the folder is that it folds. I do a mixture of rides, the more utilitarian ones are to medical appointments, yoga classes, walk n beer with mates. All of these are ~12 mile round trip with a big hill on the way back. A folder would be convenient as easier to stash the bike somewhere safe. At the moment I have taken to locking my bike directly outside the police station.
Other rides are ~50 miles of generally hilly terrain for fun. I don’t want a folder for these and I want to get some exercise so the TSDZ2 works really well - when it works
Also keen to get Mrs BM on a bike and I think she would appreciate the upright folder riding position.
I nee 2 bikes also to have a spare in case of breakdown. One might as well be a folder.
I almost bought the above Woosh kit a year ago but opted for TSDZ2 instead as I thought it would suit my riding style and the hills better - also at the time the above motor was perpetually OOS. I don’t really have any functional complaints with the TSDZ2. I know there are hubs that will get me up steep hills but from previous experience many hub bikes will struggle. Was offered a woosh Camino very cheaply recently but a woosh confirmed this would have been underpowered. I used to have a Bafang 36v front hub many years ago and that would have struggled up one of my most frequent hills. It could do the 16% with a fair amount of rider input but that wasn’t sustainable over more than a short hill.
I’m going to repair the TSDZ2 for now and see if anything turns up
Peter.Bridge
1,583
727
Possibly upgrade to one of the larger batteries ?
Bogmonster666
343
176
I am coming to the same conclusion, reading reviews this will easily manage 16% hills and ticks all the boxes. Well made, good uk support. Not sure I understood the bit about keeping upright when folded - does this just relate to long term storage or putting in boot of car?
3,344
The 806 seems expensive for a hub motored bike. Personally, I wouldn't buy one. For this price I could convert at least two old folders, and with 19.2Ah/691Wh batteries. My conversion cost £909, and £809 was for the BBS01B kid-drive kit with 19.2Ah battery - it's a very capable conversion, much more capable of dragging stuff uphill than the 806. BBS01B mid drives don't suffer from rising damp like TSDZ2s.
58236
This bike has the same frame as mine:
The only difficult part was removing the BB. Stuck because of galvanic corrosion, I think. You'll also need a programming cable.
Bogmonster666
343
176
I hear you, but struggling to find a suitable folder with disc brakes. I am coming to terms with the idea of a hub motor. Buying pre-build wasn’t my 1st choice…I don’t need a massive battery as will still have the TSDZ2 mountain bike crapcycle for long rides - these are always pleasure / exercise so reliability is less important.
3,344
Although I'm happy with the effectiveness of my v-brakes, I've been looking into converting the rear wheel to disc brake (front conversion doesn't seem a sensible idea, so far) to prevent rim wear. Good quality 20" rims wide enough for 1.75" Marathon Plus tyres are difficult to source, otherwise I really wouldn't be investigating the possibility of considering disc brake conversion, because when wheels are true and pads are well adjusted and not too worn, for me at least v-brakes work well.
Waspy
471
193
.....when wheels are true and pads are well adjusted and not too worn, for me at least v-brakes work well.
Yes that is true but putting aside rim wear and less braking performance for a moment, by your own account for the best performance from V brakes, the wheel must be true, the pads have to be kept in adjustment and the pads cannot be worn. None of this applies to hydraulic disk brakes (but obviously the pads have to be replaced when they're worn out).
I have just been out on my bike after fitting a rear Shimano MT200 hydraulic disk brake. I fitted a front one last summer and since then I've been very unimpressed with my rear mechanical disk brake.
I am a total convert to hydraulics now (thanks to bloody saneagle) and I can't ever see me going back to V brakes or mechanical disks.
One tiny problem though, my hydraulic hose is about 200mm too long, so I'm going to have to get on Youtube and learn how to shorten it. Onwards and upwards.
3,344
If disc brakes are so good compared to v-brakes, I can well understand v-brakes being a dealbreaker. After resuming cycling in 2019, having given it up in the late 1980s, I haven't ridden a bicycle with disc brakes - I found a bike with a front cable disc brake dumped in the woods a few months ago, the thing wasn't rideable but the front disc did seem to stop the bike pretty effectively when I tried it while pushing it along home. If I do decide to go ahead attempting a rear disc brake conversion, if this front brake fits onto the rear disc brake adapter, and it works ok, I'll upgrade to hydraulic. It'll be a pain, because of course I'd have to replace the rear hub with one for disc brake first, and build a rear wheel. A front disc brake conversion doesn't currently seem viable.
58239
Reactions: Waspy
Bogmonster666
343
176
If nothing else, I get through a small fortune in brake pads and need to adjust for wear every few outings. My hill is steep, single track, covered in loose gravel, high hedges and sharp bends. It’s the sort of hill you descend at 10mph in case you meet an idiot in a car coming up that refuses to stop. And I’ve met a few
Peter.Bridge
1,583
727
:) Exactly the same - I fitted the MT200 at the front - no maintenance - just as good as the day I got it, I'm getting unimpressed with my rear mechanical disc brake, which I swear has got worse over 2000 miles use and I have a MT200 ready to fit (total convert to hydraulic brakes - bloody @saneagle is to blame too ! :))
Reactions: Waspy
3,746
Don't waste your time with cable disc brakes. Anybody that has them should immediately swap them for hydraulics. The whole concept of the way cable disc brakes work is flawed and can be dangerous if not given ridiculous amounts of maintenance.
Reactions: guerney
mr_ed
116
18
What a load of shite… instead of just stating your opinion as fact as usual, can you back this up with some reasoning and evidence?
There are millions of bikes with cable disk brakes and all the major brake manufacturers make them. Are you saying they’re negligent and the riders are going to suffer death unless they spend an hour a week maintaining their brakes?
…or actually are they just fine, and no better/worse than any other brakes.
Here is a balanced view, presented with reasoning and explanation rather than just stated as fact….
Waspy
471
193
Nowhere in that article does it mention E-bikes, which weigh more and have higher average speeds. Consider that mass going fast downhill.
Let me ask you a question, how would you fancy cable operated brakes on your car or motorbike?
Anyway, enjoy getting torn a new one by saneagle :D
Peter.Bridge
1,583
727
I bought a pair of cheapo Shimano MT200s off AliExpress for £35 including delivery (they even swapped them round to Right Front. Left Rear before they sent them for me)
My Facebook marketplace £50 15 year old Carrera Vulcan donor bike (that didn't look if it had been used) had cable disk brakes. I swapped the front brake to the hydraulic one about a year ago but left the mechanical rear brake (at that point I could lock the rear wheel riding on the flat using the mechanical disk brake). Over 1 year and 2000 miles the front hydraulic brake is still really effective but the rear mechanical disk has become far less effective (neither of which I've done any maintenance to). I will swap that one over too now.
I've seen people on here have bled hydraulic brakes, (does it vary by brake brand/model ? Saw this https://bicycles.stackexchange.com/a/6463 ) but I've not had to either on my Carrera or my 10 year old Boardman mtb(I think I use the brakes more on the MTB). They are still really effective, could lock the wheel if I pull hard enough.
For £35 I think it is a no brainer to swap over.
Reactions: Waspy
8,734
Hydraulic disc all day long on any bike, my pad bite just gets better all the time having bed in nicely . Cheap china pads at a £1 a go and no issues with their performance , only another dozen or so pairs to get thru so should last me for ever.
Reactions: Peter.Bridge
