Fitting yose power
2,826
as said clean the BB threads both sides .
and be careful of sharp burrs that can be there; they can easily cut if you aren't, and dirty greasy cuts aren't nice.
Reactions: detec52
Cadence
298
219
I have ordered my motor ect from Yosepower I took the rear wheel out and managed to get the gear cluster off but then loads of small bairings fell out ouch how the heck do you get them back in? Or will I need a different 6 speed?
That looks like a 6-speed freewheel. Instead of unscrewing the complete unit you have removed the lock ring and inadvertently disassembled it - hence the ball bearings falling out. The part that is still on the wheel needs removing anticlockwise. There is a video here about removing freewheels:-
Your problem will be getting a grip on the remaining part, which might be very tight. I would suggest a Stilson wrench and a piece of tube, or if you have a vise, grip it in the jaws and turn the wheel. Either way it is easier if the tyre is still on the wheel.
I wouldn't try reusing that freewheel now, so you will need a new one - some listed here:-
Make sure you order a freewheel kit from Yose - not a cassette kit.
The Yose kit comes with a Shimano compatible freewheel tool.
detec52
Thankyou that's good advise I see where I went wrong, I do have a good vise so will remove it as you said many thanks.
