Help! Fitting TSDZ2 on a bike with internal cables and hoses
IAmNotABear
Dec 3, 2024
Hello, I am new here and I'm really impressed with the pedelecs community that guided me through my research, however I wasn't able to find a solution to my problem either here or youtube (maybe I used the wrong keywords?)
I am planning to fit my Specialized Sirrus 2.0 with a TongSheng TSDZ2B as it seemed like a perfect bike for a conversion, I am worried however that I might not have enough clearance between the top of the motor and bottom of bracket shell for the derailleurs and hydraulic hoses cables, as these cables are going internally and leave at the bottom of the down tube.
I am not too worried about moving the cables around as it seemed easy enough, but I am worried about the hydraulic hose as it seems like a complicated process to replace the hose and require a lot of special tools.
Do you think the motor will fit? if it doesn't is there any way I can make it fit without moving the hose?
I attached pictures of my bike, apologies for the dirt.IMG-20241203-WA0040.jpgIMG-20241203-WA0042.jpg
matthewslack
1,880
1,363
I don't think it will fit, but you should not be scared of rerouting the hydraulic hose. All you need is a new nipple and hose insert, although often the existing one will reseal OK, and a bleed kit, and some of the right kind of brake oil or fluid. Only a few £ or € or $, and half an hour of careful work.
Reactions: IAmNotABear
harrys
358
99
73
Chicago, USA
I would hate to dremel a nice bike even though it's cosmetic. I've rerouted mechanical lines, bled hydraulic lines, but have yet to break and re-install a line, I would do that first.
Does the ToSeven DM02 have more clearance to the downtube?
IAmNotABear
Dec 3, 2024
dremeling might be necessary for this one even if i move the hoses because of the cable exit ramp.. I don't like dremeling my bike but the bottom will be invisible anyway
matthewslack
1,880
1,363
You could buy a cheap second hand brake on ebay to practice on.
