FENETIC SPRINT EBIKE
8,582
Connect controller, battery and Phase /speed sensor wiring. Then display and PAS, check PAS operation first then connect throttle if used & then brakes.
cardsharp1
18
Pic #3.
I can make out three wires on the bikes brake sensors. Black/Gnd, Blue/Sig & other Black (likely has another colour stripe unseen to donate 5v) please confirm . Connect to the three wire brake.
If you want to use the second brake sensor simply omit the 5v connection to the two wire connection.
Some connector or wire joining is needed,
there are 2 cables both with 2 wires a black & a blue wire
8,582
Ok, the third which I thought is a reflection on the bike paint.
You can still use both if you wish, on the 3 wire controller brake leave the 5v disconnected and it should work. Tbh only one brake cut out is often needed on the rear brake.
cardsharp1
18
yes ill just use the rear brake which is the best connector to use
8,582
The two wire one.
