Faulty eCarrera Crossfire
egroover
1,082
650
57
UK
Seems we've got MK1 then :-(
thats the mk2, the latest is the mk3
the original mk1 crossfire-e had this display
43319
Eejit
13
That's brilliant. Thanks. Hopefully when I get this pin sorted it might be the end of my cut-outs
RickyB
Not sure what you mean by the Pin?
When mine cuts out, I either just get a blank screen, or sometimes error code EOO. Just looked at the manual and it says:
Error 00 - Controller communication problem - Remove the Battery for 5 minutes and then Power-on again.
Well, that's fine, if you carry the battery key around with you all the time (which I don't). Also, not much use if you're in a hurry, or in heavy traffic etc, when it happens..!
JimC
Jul 29, 2021
I bought a secondhand Crossfire in May, it had only done 4.5 miles, the owner wanted a bike he could de-restrict and apparently that isn't possible on the Crossfire.
As you can imagine, the bike was in showroom condition.
All was fine for a while but then the dreaded cutting-out started, I had to keep restarting it with varying success.
Anyway, I took it to my local Halfords, they had a look at it and decided it needed a part they couldn't get, odd.
They simply gave me a brand new replacement, it was a bike they were about to put on display, they never even asked to see the receipt, (I have the original purchase Receipt)
The problem now is that the new bike is at least as bad as the old one, I've just come back from two weeks holiday in very hilly areas, sometimes it worked, often it didn't.
The problem varied, sometimes it just wouldn't turn on, even though it showed on the display, other times it felt like it was only working on one pedal, i.e. half a revolution and other times it seemed to surge. Sometimes It only worked when I pedalled really hard uphill, as soon as I relaxed a bit it stopped.
I've taken it back now and await their response, the problem I have is having bought it second hand I'm not sure how they'll view the warranty situation...
Eejit
13
43329
The pins are spring loaded and you can see from the photo that pin 1 is depressed and not returning. I think that this is the issue with my cutouts as it happens only on my wife's bike when she has this display.
I need to figure out how to split the case and see if I can repair it.
