Hi Alex of course you are absolutely correct and to be frank the silver one is not a problem, the bikes that get me down are the black framed versions that are made to look as close to a Wisper as possible. I find it amazing that although these people insist they are not copying our bike, the webs and curves are all in about the same places!Why is the kettle plug dangerous and illegal?????
I saw in one of your manuals that you also use or were using this kettle plug in your batteries??? Is there any problem with them?
Also you seem to be very sensitive David to all the bikes that have a curvy tubes. i noticed that you claim that all the bikes that use curvy bent tubes are copies of Wisper 905. That silver bike of Bruce in fact may have some similarities to your frame it is a totally different design, Firstly is awful and has a massive head tube that is not needed. Secondly is also totally different in terms of shape, bending angles, controller box etc.
I surprised you claim it as a copy of your bike. You certainly don't have any exclusivity for the curvy tubing and everyone is allowed to use them. i worked in the bike shop for many years and seen hundreds of different push bikes. I tell you that if every manufacturer thinks like you then they would all be blaming each other for making clones and copies because the normal push bikes industry is so saturated.
Remember bike is a bike, it is built from about 4 different tubes excluding the head and seat tube. You are therefore very limited to what you can do in terms of design. To me claiming that anyone who uses slightly similar shape to your frame is a clone maker is totally ridiculous. Bruce does not advertise his bikes as Wispers or similar to Wispers so you should not call him a clone maker. I'm certainly not keeping his side and neither yours but trying to be very neutral. BTW I really do think that Bruce's collection is awful and sucks with cheap Chinese bikes but i would not call him a copy maker.
And the last one who is Phill that you are talking ABOUT, did not get it at all?
best regards
Alex
I do get tired and emotional too easily (I should probably take a holiday! ), I simply can't help becoming annoyed when people blatantly try and pass their machines off as Wisper bikes.
The Phil comment was not really for the Forum, it will only make sense to those 100% in the picture. I think it is probably too late to delete it though.
Thanks for your comments Alex, I appreciate your concern.
We stopped using the kettle plug quite a long time ago now on all our bikes. The problem is that it is easy to plug the mains supply straight into the battery if the same connector that should go into the charger can also be fitted straight into the battery.
All the best
David
