C
Cyclezee
For those with a need for speed and private land to ride on, eZee have a 28 mph, 45 Km/h 'S' class which is popular in Germany.*
The eZee Torq 45 is available to order with several options, the basic specification is as follows:
Price from £2200 / €2800
*Cyclezee will require a disclaimer from anyone from the UK buying this model stating that it will only be used on private land.
Motor | eZee 500 watt / 350 rpm |
Top speed | 45 kmph / 28 mph |
Battery type Wh | 37v 14 Ah 10s 7p (2200 mAh, 5C Samsung cells ) 518Wh |
Consumption | 21 Wh / mile at full power |
Max range | 30 miles |
Battery option | 37V 20Ah (2200 mAh , 5 C samsung cells ) 740 Wh |
Max Range | 43 miles |
Bicycle weight | 23 kgs |
Battery weight | 3.8 kgs |
Brakes | Hygia hydraulic brakes with electric cut off / Hall sensor |
180 mm disc rotor | |
Gear | Shimano Alfine 8 - 306 % |
Option | NuVinci N360 360 % stepless variable |
Light | eZee L 1000 : 1000 Lumens |
Operation mode | Multiple options : ebike + pedelec, pedelec with 6 kmph ebike, |
ebike, cruise . Motion sensor : 12 poles and 2 Halls | |
Option | Pedelec with Thun torque sensor |
5 power level selection or Cycle Analyst |
