Expected lifetime of a BBS02
5,786
yes, but I guess it's easy for Gospade to use the more popular 5 bolt 130 BCD like the Tongsheng TSDZ2.
more info here:
https://www.gospadebike.com/motor
They modified the standard motor for me to test with higher torque, not quite as strong as the 48V TSDZ2 but not far off, around 90NM.
the Gospade is quicker to install than the BBSes and TSDZ2.
Price-wise, same as TSDZ2.
I came across a comparison of the BBS and the TSDZ2 for vélomobile use on a Belgian site, the TSDZ2 is recommended for stop/start around town use and the BBS for long-range commuting. Both motors have modified vélomobile specific settings. I am thinking a 44.4v 17 Amp GSM will do quite nicely in a vélomobile... ;)
8,843
5,786
Deere John
532
580
48
EU
One addition to the lifetime aspect of things.
I have now opened my motor with self made gaskets using this engine silicone-gasket-on-tube-thing. Works great! You have to be meticulous when doing it and it will get great!
Reactions: Gurnard
Stavros
Sep 24, 2018
I've got a BBS02 750W since March 2017 (so approx 3 yrs now) and travelled 11300km (7000 miles) to date without faults. My daily commute is about 20km (12 miles) round trip, most of it over flat terrain and in relatively ok weather (Brighton, UK).
My two cents on the motor, cycling style and other ebike stuff:
All motors have two power ratings, the nominal rating and the peak rating. The nominal is the 750W (or 500W, etc. advertised on the product), and the peak rating is the maximum the motor is allowed to produce without undergoing significant damage (ie not overheating too much or causing significant wear) for a particular amount of time.
The peak power output for the BBS02 I belive it's about 1200-1300W. You will be able to achieve this kind power only when pressing the acceleration button. The power output with pedal assist is limited to the nominal power.
For a long lifespan I would definitely recommend driving it at 750W (or whatever the nominal power of your motor is), or below. You can set the screen to show the power output in the settings.
You most likely won't need to go over the nominal power, unless you want to have some fun. For example, I weigh 100kg (220lbs) and would not feel the slightest effort when pedalling up very steep hills ( with max pedal assist level), the 750W power is more than enough to push my fat bum up a steep hill.
In the link below you'll see what I mean by steep hills. It's 1km long and 100m change in altitude ( left side of the screen you'll see the details of the route) - pure mental and physical pain for the amateur cyclist.
My other recommendations for a good e bike build are: 1. buy a good battery (samsung or lg cells) and 2. schwalbe marathon plus tires. These are more expensive than the average stuff but in the long run you'll avoid other costs and headaches with breakdowns/repairs.
The lifespan of a battery depends mainly on the quality of the cells, which in turn will give a high cycle ratio. For example, cheap no-name batteries will have 4-500 cycles and the good cells (samsung, lg) can provide 7-800 cycles. A battery cycle is measured in 100% to 0%! power hold, not how many times it's charged. At the end of the day if you still have say 30% power in it, then this would represent 0.7 cycles, 50% power left - 0.5 cycles and so on.
The cycle rating of a battery does not mean that it will stop working when it reaches the number (ie 500 or 800), but that it will start losing hold. For example, I have a 48V 11.4Ah samsung battery and could do 30km at the beginning but now after 3 years I can do about 25km. After a year of two it will drop to 20km, etc. So if you're round trip is say 30km, would be best to buy a battery that would provide 40-45km - ie check a battery with 14Ah capacity. Also, if you're commute is likley to change in the future (ie changing jobs or home) then a bigger battery would come in handy.
The battery capacity also depends on how heavy you are and how you use the bike. I'm 1.9m tall, 2m wide and travel to work mostly with the acc. button (always keeping it below 750W), I don't pedal too much for several reasons, one being to keep a low gear to have the motor spin fast (electric motors love to spin fast) and reduce wear on components.
There's another element that controls the lifespan of a battery and that is called a BMS (battery management system). In short, it ensures that all cells discharge/recharge at an equal rate - all have the same no. of cycles. This BMS is of less importance compared to the battery quality as it's quite cheap compared to batteries and reputable vendors will go for the good BMSs. You want to make sure the battery has a BMS.
The volage of the battery should be as the nominal voltage of the motor - ie for the bafang bbs02 750W 48V, buy a 48V battery; for the bbs02 500W 36V - buy a 36V battery. Some recommend a higher voltage battery (ie a 52V for the 48V motor model) but this will put additional pressure on the motor's 'BMS' (there's something similar in the motor that controls the voltage intake).
Regarding the schwalble tires, I can't recommend them enough, they're quite expensive (£25) but definetly worth it. I've never had a flat in over 10K+ km, and I went over big chunks of broken glass (not on purpose) several times at high speed . These things are unbreakable. From the amount of wear I see on them I think they'll be good until 15k km. If you swap them around, put the rear tire on the front wheel and viceversa, at about 7-8K km I think you'll be able to get 20K km out of them (I know, it's crazy). Best thing is to check them every couple of months and see how much wear is on the rear tire compared to the front one, and if the there's a noticeable difference then swap them around.
About other bafang components, I would suggest buying the largest chainweel available (for the bbs02 I think it's 52T or 56T), if you're planning to use the bike mainly in the city and have long strips of flat road on your commute where you can go fast. For mountain biking buy a small one (ie 36T or smaller). For the bbshd model I think you can find 52T or higher chainweels from other manufacturers and are quite expensive.
If you live in the UK then check out eclipsebikes (UK shop), they don't hold too much stuff on stock but it's the cheapest vendor I could find. Otherwise check EM3ev (based in hong kong or thereabouts) or Luna Cycle (US). FYI if ordering from these last two beware as the taxes on imports are quite big. I bought my bbs02 from em3ev and paid £40 only on import tax (in 2017), a friend bought the bbshd from em3ev last year and paid £120 on import tax - note that this is for air delivery, for shipping there's some other play. Em3ev have great customer support (always replied within 24hrs and I had quite a long correspondence with them) and also a team in London for repairs from what I was told. For batteries em3ev are the best in my opinion, haven't seen anywhere else so much diversity on both battery size and cell quality.
Never ordered anything from Luna Cycle but from online videos they seem to know what they're doing and are passionate about ebikes, have plenty and good videos on youtube.
For further info and videos I recommend Ebikeschool and BrunoPOWEEER - he's crazy but top on bafang motors, also he did a tour of the em3ev battery assemby factory.
All the best,
S
Reactions: Jaxter
gw8izr
239
253
Just a thought / ramble but:
When we try to seal / waterproof a motor or gearbox it’s worth thinking about how it breathes, we get them warm by using them and then spray cold water or even potentially dump them under water.
When they warm up the air inside expands and is shoved out through any gaps and when we cool the casing quickly any water on the seals is drawn in through any gaps.
This effect over time has been the cause of many vehicle transmission failures, if I discover rusty bearings in a Landrover transmission it’s always been due to a blocked or kinked breather.
If those breathing gaps are only round the seals then for sure dirt and water will be drawn in through those seals or where wires pass through grommets.
I looked at the TSDZ ( my only example of this type of motor ) and it does look like the BB is the likely ingress path, so much so that I blocked the unused mudguard fixing hole and it’s my hope that the frame tubes will provide some elevation for this breathing. I’ve not broken mine so have resisted pulling it apart so this is from external inspection but I’d be interested to know where the air paths are.
Reactions: Deere John
Deere John
532
580
48
EU
Interesting. Maybe drill a hole on the bottom and put a gore-tex membrane there :)
gw8izr
239
253
Well I’m sure you know that Gore-Tex would only let vapour through and soon becomes waterlogged, any breather needs to be above the water line. The concept of a breather venting into the bike frame I’m sure would stop the potential problem of dragging grease/dirt/water through crank seals and drive axles et cetera.
As above I don’t know what the passageways are like in these motors but there was a small outdoor unit used for microwave links, it was very similar in size and construction to my crank drive and was sealed with a number of O-rings on aluminium castings. These units were incredibly reliable, definitely fit and forget. Then all of a sudden lots of them started failing. The fault diagnosis came back as water ingress due to faulty installation, I knew that was incorrect as these had worked for years without being touched. I split one apart and looked and it had a good half a cup full of water in it and no way to get water through glands. No effective breather.....
The diurnal temperature change and pressure/vacuum combined with condensation on the casting over the years had pulled water past the o-rings. The 10mm hole at the top had been drilled and tapped and a mild steel vent fitted. The part had corroded due to being dissimilar metals in an electrolyte, once replaced with a plastic part which remains clear that unit retuned to its legendary reliability :) job done!
17,440
there is an airgap around the chainring plate (where your 5 M6 chainring bolts go), so there is no differential air pressure. Since 2017, the BBS01 have oil seals on the bottom bracket, reducing the number of water ingress cases considerably - I see no more than one case a year now.
The most frequent incidents are still blown controllers.
gw8izr
239
253
Well there we go, as I said I haven’t had one to bits so so it was all conjecture anyway :)
Does the BBSO1 have some method of breathing through a different route rather than past those seals?
17,440
there is no seal around the chainring plate.
The idea is the water would get though if you submerge the unit, and would collect at the bottom of the gearbox without damaging the main bearing. Collected water would evaporate shortly though same gap.
I often see rust particles encrusted in the gearbox grease around the main gear cog teeth while the ballbearings remain undamaged.
Reactions: gw8izr
Deere John
532
580
48
EU
...yes, look at my BBS01 on last service, it looks like someone has pooped in it...
[hr]
But now... after that service, I have had no more problems what so ever. After almost 5000 km in various conditions. Many wet muddy trails have it been. I have not been gentle to it but it lasts very good! I am very impressed by this unit actually. After the rotor upgrade I really love the unit. Whish I had tried this earlier (before I bought a Bosch CX and tried for 2 years and decided it was crap before switching to this)
Reactions: Nealh
