Exiting New Things
  • Start date
1boris
344
58
Very good news D8veh.Thanks for the offer.But I am in Norway.So easier to order myself.I contacted a suplier first thing as soon as I saw your post.I was just waiting for your review.Does it make the same noise all the time or only on climbing?
1boris
344
58
I saw a picture of the motor on pedelec de.I belive the gears was of steel
It makes a bit of resonance all the time, but when it goes very slow under load, it changes to a grating noise. It's worse at 36v because of the lower speed. The noise isn't a deal breaker for me, but could be different if you want to con the lycra brigade.
Reactions: saneagle
I was sending from Tapatalk, which won't work properly on my phone. I try and post a message and it stalls. Whether you go back or forwards, you can't see what's happened.
I'm not sure that our German friends have got it right. I discovered today that there are two elements to the gear-changing decision: Torque and speed. Both can be measured by the controller CPU using the current and hall-sensor signal.
If you force it into low gear, then stop it and lift the wheel off the ground, it always starts in high gear, but if your weight is on the bike, it starts in low gear.
There cannot be any sort of solenoid inside because there's no wire thick enough to power one. That's if there's any spare wire at all. I'm pretty sure that the white wire isn't connected. If the gear-changing were mechanical, there would have to be torque on the motor to change gear, but the changing happens while it's free-wheeling or stationary. Another point is how the controller would know to cut the power while it's changing. I can't see how it could be triggered. the changing has to be initiated by the controller - as I said by two simple conditions - speed and current (or manual switch). Also, to change gear from the switch would need a solenoid in the motor, which i don't believe it has.
Everything, to me, points to the controller making the motor reverse direction to change gear despite the patents banded about. I think they're red herrings. This method is simple, logical, and doesn't require any modification to the controller other than software. all it needs is a double ratchet/clutch in the motor.
The mystery will soon e solved when I get my next ones, which will give me the chance to open one.
trex
7,703
2,671
It's exciting in the sense that it could potentially get rid of crank drives altogether if we can have 3 gears.
it's early days for the XD, I would wait another year for the product to mature.
shemozzle999
2,826
686
I too hold some reservations after seeing the photos of the drive train. It appears to be metal geared and knowing that the freewheels can sometimes seize up, if it operates how we believe, then what would happen if the motor changes direction but the freewheel doesn't release?
I wouldn't over drive this motor.
trex
7,703
2,671
All motors have a very, very small risk that the gears break up inside causing the motor to seize up. The risk isn't much greater because the cogs are made of metal. I had opened a Xiongda motor with a cog that had two broken metal teeth, the debris simply got ground down to a couple of small (1mm) pieces by the cogs and stuck in the grease.
That risk may be twice on the XD because it has two planetary gears, then again, should be 10 times greater on a Nexus 8.
drsolly
196
Yes, I've tested it. I love it apart from the noise it makes. It sounds a bit crappy, but functionally, it's better than the Panasonic Erace P. The climbing power is immense, especially when you run it at 48v like the Panasonic. I've ordered another five, so there might be one or two going spare for forum members. Get you name down now if you want one.
I'm interested, what will the cost be, and what components do I get for that?
Not expensive. Controller, PAS, throttle, motor, LCD, gear switch, i can probably build the wheel into a rim if you want.
C
Cyclezee
I also ordered an Xiongda double speed motor at the weekend.
This one is a front wheel kit and the forks need to be stretched to 110 mm.
I like the idea in principle, just a bit concerned about the noise with metal gears after riding an old geared Heinzmann last week.
drsolly
196
Thanks - let me know when you're ready to roll (I'd still like an actual cost before I totally commit, of course). I'd like it built into a 26 inch rim; I can do that myself, but I'm not very good at the balancing, don't bother with tube and tire. I don't actually need PAS, and I prefer thumb throttle.; I can change it myself if a twist throttle is the only option.
I use a bike for geocaching, it's all stop-and-start, with lots of soft ground and some steepish hills. So what I want is torque, top speed isn't so important. The gear change sounds like I'd get the best of both worlds. I run from Lipo, if the motor is 36v, I'd use 12S, which is nominally 44v, 50v when fully charged.
The donor bike is a pretty standard folder, steel forks, and I use a torque arm. Telford's not too far from me, I could come and collect it (and meet the guru!).
Arbol
391
25
trex
7,703
2,671
The picture doesn't show the e-brake (two small wires) levers and throttle (3-pin white plug). The small round thing with a switch at the bottom of the picture is the Low/automatic/High gear selection. Just leave it in the middle and hide it in the controller box then the rest is fitted like with a rear hub kit.
Reactions: Arbol
The controller has two two-wire connectors for e-brakes. They didn't provide the levers, but they did provide a plain full-width throttle.
I think they sell all the parts, so you can get whatever you want.
Reactions: Arbol
