Help! ERROR 08 upon Setup
kbmetal
12
A new Brushless controller called 36V 18A BLDC motor controller S866 LCD Display connected to a quite old front hub motor gave me ERROR 08 after self learning process. Nevertheless motor is turning smoothly. I am convinced it is a HALL related error although supplier calls it Throttle error and has sent me a datasheet with that explanation. There is no throttle connected. If I remove 5 HALL cables error and smooth running does not change.
3,994
E08 means that the throttle isn't in the zero position when you switch on the LCD, but it might also come if your throttle signal is out of range (less than 1v or greater than 4v). I'm pretty sure that E07 is a motor hall sensor fault. I would guess that the causes are related and probably due to an intermittent problem on your 5v rail somewhere. Unfortunately, the PAS, hall sensors, throttle, brakes and controller all use the 5v, so you have to check everywhere to find the fault. It could be a zip-tie pulled too tight, water in a connector, damaged wire or something like that.
It's easier to find faults when you have a total failure. Intermittent problems are very difficult to solve because everything is working when you do tests. A couple of times, people brought their bikes with intermittent faults to me to fix, but after a quick check and a ride around the block, I had to tell them to take it away and bring it back when it didn't work.
TERY
Jan 14, 2025
E08 is exactly the throttle sensor error.
I was crazy about it for a week. I disassembled all the parts of the electric bike, also replaced the engine sensor but the e08 error was still there. So crazy.
And I thought about the throttle sensor. Measured the continuity of the wires, but the throttle sensor seemed to be short-circuited. I used a sharp object to separate the 3 pins of the throttle sensor. And so the e08 error was fixed.
Thanks forum.
