Help! err 30 code
dphkeith
Jun 22, 2023
hy can anybody help point me in right way . code 33 then code32 now code 30 help basis beacon chears
6,354
Error 30 indicates a communication issue between the display of your bike and the internal controller. Somehow, the two aren't communicating properly. Typically the issue is: 40% Internal Controller.
The manual and this guide outline this Error 33 means over current, and to check connection between the controller and the motor.
dphkeith
Jun 22, 2023
Thanks going in right direction now
2,195
Over-current is a blown MOSFET in the controller. You can check that by measuring the resistance between the battery red and each of the three motor phase wires, then repeat for the black battery wire. Each group of three should be the same as each other and in the range roughly 5K to 20k.
It could also be a damaged motor cable, so check that too, especially where it comes out of the axle.
When you have a dead short like that, it will give the other problems.
