They used to be 1A, now they're 2A., out of interest, how much current does a standard Samsung charger provide? The standard Apple iPhone one provides up to 1A and the phone does draw close to that when the screen is active and the battery is charging. I've heard that this gives problems when iPhones are connected to some ebike USB power sources that can't provide that current.
I eventually went for 2 x 2ce for back of trailer box, 1 x View E-Bike 5V - 15V DC Rack Mounted for back of trike, 1 x Avy E-Bike 6V - 42V DC 40 Lux Head Light for front of trike all from probikebitzN.B. Before you head down the USB powered route......check your battery's USB output actually works. Why ? Well, some of the Hailong-type (HL) battery pack have a USB port, but no internal electronic circuitry between the port and the battery output.
If you have the VLCD5, and a splitter on the speed sensor connector, you can use the VLCD5 button to turn on/off a 6v output.
TSDZ2 NEW Speed Sensor with Y Splitter for Headlight and Taillight Connections | eBay
Find many great new & used options and get the best deals for TSDZ2 NEW Speed Sensor with Y Splitter for Headlight and Taillight Connections at the best online prices at eBay! Free delivery for many products!www.ebay.co.uk
The following are low-cost, high-quality Ebike lights that work directly from this supply.
Axa LED Headlight " Blueline 30 E-Bike " 6 Volt Dc
Busch + Müller View E-Bike 5V - 15V DC Rack Mounted
*Busch+Müller View E-Bike 5V - 15V DC Rack Mounted E-Bicycle E-Bike Electric | eBay
Find many great new & used options and get the best deals for *Busch+Müller View E-Bike 5V - 15V DC Rack Mounted E-Bicycle E-Bike Electric at the best online prices at eBay! Free delivery for many products!www.ebay.co.uk
Busch + Müller 2C E Rack Mounted 5V - 15V DC Rear E-Bike Light
*Busch+Müller 2C E Rack Mounted 5V - 15V DC Rear Light E-Bike E-Bicycle Electri | eBay
Find many great new & used options and get the best deals for *Busch+Müller 2C E Rack Mounted 5V - 15V DC Rear Light E-Bike E-Bicycle Electri at the best online prices at eBay! Free delivery for many products!www.ebay.co.uk
Lots of choice there. This one looks good, but I think I may have the bits to make a small switch mode PSU, and if so it'll be another diversion during the lockdown.https://torquetech.co.uk/collections/dc-dc-converters
I have just done a 12 dc lighting system for my trike build, used a dc to dc regulator rated at 20amps this will run several other devices too. check out the link stocks 5v usb as well
ps he is a member on this forum
Well what do you expect to pay for a must have fashion item? It's got an Apple on it mind.Would that be the latest iPhone that costs more than £800, but less than the one that came before it ?
Depends on the bikes usage, my commute /errand bike has fixed lights running off the battery, I never have to worry about charging or forgetting to have lights.Normal cycle LEDs are so bright and the batteries last so long it's not really worth the hastle of wiring to the main battery.
On second thought, is it worth the trouble? I think not.Lots of choice there. This one looks good, but I think I may have the bits to make a small switch mode PSU, and if so it'll be another diversion during the lockdown.
