Any tips for good security locks on ebikes ? most insurers now stipulate minimum lock standards - what are people using out there? any thoughts on the Axa Basta range?
cheers
cheers
I do the same (lock through the rear wheel, where the motor is) - but it's only because my cable lock is not long enough to go through the frame.i always put my lock through the wheel with the hub motor in,my thoughts being that the frame would be useless without this,i also carry the battery indoors when possible.
In googling the AXA lock, I have just come across this link posted in Holland a few days ago. It suggests that there is a serious problem with these locks (see the YouTube detail lower down the page).I've never heard of a theft of the number 1 type, the cables from the motor often being a good deterrent. However, it's often possible to fit the AXA type of wheel lock, even on the front fork of many bikes, mounted on the other side of the V brake position. This puts a circular hard steel shaft through the spokes in the locked position.
It can be seen on this link, and the accessory cable allows it to be used for securing a bike to a stand, lamp post etc:
AXA Lock
So what is the situation with the lock on the Kalkhoff-safe or not ?Thanks for the information James.
I used one of the SL7 with cable for years without problems, and did try to trip it in various ways without trying very hard though.
In this country I don't think it's a problem, simply because of the rarity of these locks, mine was the only one I ever saw in use. Our bike thieves are generally a crude lot who operate with bolt cutters, which are useless on this type of wheel lock, and I expect they'd just move on to a cable or chain locked bike instead when coming across one of these.
Also, for anything other than a very short term stop, two locks are best, and the AXA would be still be a deterrent as one of two. I also use an alarm.
Seems nearly impossible to say, since with lock after lock of all types we've been getting these scare stories, leading to the conclusion that none are any good.So what is the situation with the lock on the Kalkhoff-safe or not ?
Chris
I'm sure a bolt cutter could easily chop straight through those Stuart, either the chain links or the locking arms, they look worse than useless.Also, do these types of 'street cuff' locks have any inherent security advantage over D/chain locks (though they're horrendously expensive ).
Stuart.
