Help! Ebike kit I can carry in airports and charge my Macbook
3,277
Of all the kits I have had BBS01 and various hubs front and rear because of the light weight and small mass, it is by far the easiest to ride over and above the 25km/h cut off and with none of the treacle ( dead weight mass) associated with other drives.
That does sound good, why not get one of those @cwah?
8,565
Price maybe. The Revos is UK designed and made.
3,277
Yes, that is eye-watering in comparison... Saying British craftmanship is more expensive doesn't seem to apply to furniture makers, it surprised me to disover - I know a local firm who source cheap parts from all over the world, and weirdly the UK supply is sometimes just as cheap or cheaper than say Romania or Poland. But that's furniture...
3,277
I recall seeing the Revos people on Dragon's Den a while ago, and they rejected a suggestion from Peter Jones to source cheaper parts from Asia. They "Left with nothing".
cwah
3,048
179
www.whatonlondon.co.uk
Voltage isn't everything then. Maybe the OP will be fine with his initial choice of kit?
Voltage is increased to reduce resistance. A low power kit can afford a much lower voltage.
Whether the kit is 24v, 36v or 48v, all that matter is the wattage output. So usually I see this more as an incompatibility problem than anything else
cwah
3,048
179
I wouldn't mind buying from them. A bit annoying that I'm not in the UK anymore (i m in paris now) so I'd have to pay customs........ :/
I'd need to ask about the total weight of the kit excluding battery. It looks to be heavier than the qiroll... the quiroll motor is a wapping 520g!
Also, they have 200wh battery. I know for sure this won't pass the airport. With the qiroll battery at 125wh, I still have some hope they will let me pass.
But I'll send them an email and see if they have any suggestion for my travelling situation. Maybe I can get lucky we never know!
cwah
3,048
179
Looking at revolutionwork, the system looks a bit more bulky than qiroll. I expect it to be heavier although I don't know by how much...
Also, it looks like I wouldn't be able to use my own batteries from their FAQs...
"Can I use other battery packs with Revos other than the one's that you supply?
Sorry no. The batteries are matched to the motor controller and the Revos won’t work with another battery and may even be damaged by it. Our batteries are excellent value for money and you can obtain another battery from us on its own if you want to"
I still sent them a message... will see what they say
3,277
Maybe you could post the battery to yourself (virtual office or mailbox service in the next country) before you move, or ask someone to post the battery to your new address once you've moved? Bypass the airport confiscation risk. Get the postage insured etc.
3,993
I can certainly see the appeal, small and light... just wish it was 36V or more. Mind you, at a higher voltage they'd likely need heavier batteries, which somewhat reduces it's small and light appeal. Well, I hope it works out... hope you'll report back when you've tried it out.
Cwah isn't a big guy. As far as ebikes are concerned, he doesn't need as much power as most of us.
Reactions: Nealh and guerney
cwah
3,048
179
Shipping battery is expensive and i may be hit by customs too. Not to mention the packaging requirement to keep the pack safe.
My view is rather to keep a low cost battery (under £100) with me and buy a new pack if it gets confiscated
Soliour
Jan 16, 2021
Revos previously did a 100Wh battery. They don't offer it currently on their website but worth asking if they can still supply them.
Kneebiker
50
I know reviving this thread is probably a big ask but....@cwah , did you getbthe qiroll in the end ?
I'm condsidering it for my brompton which has front dyno hub, rear SA 3 speed and I need to Physically carry it quite a lot on a 4 hour multi transport bi weekly commute (london to peterborough)
I've a 5 /6 mile commute at the end I'm too slow or too sweaty atm. I'm also carrying a backpack with 2 days clothes including a full business suit and shoes
Flat route mostly on national route 63
Anyway worth an ask here as this is the only proper trustworthy lead that google threw up !
Cheers
Kirstin
WheezyRider
1,690
938
Cheers
Kirstin
Might be worth talking to @StuartsProjects he has a Brompton with minimalist set up. We did talk a while back about Bosch power drill batteries. The smallest of these (2.6 Ah) would be airline compatible.
