E-Bike suitable for towing Special Needs Trailer
-Bucks-
57
North Yorkshire, U.K.
Hi new to the forum! we are looking to purchase an e-bike to help with towing our 13 year old disabled daughter in a Wike Special Needs Trailer as it is getting too much like hard work for me now!
Any recommendations/advice on suitable bikes would be much appreciated, ideally we have not much more than a £1000 budget as this is money we are having to borrow!
We are considering the Halfords Carrera Crossfire-E! Do you recon it will be suitable & have the power to help in towing the trailer?
At the moment we have Carera Valours! I don't know if converting one of these would be a viable option?
Any help & advice would be much appreciated
5,786
Looks like a good bike for a kit. May I recommend changing both the brakes for Magura hydraulic rim brakes, just the front one works well for me and my fully laden shopping trailer (40 kg). That will set you back just under £100 and add the price of a kit £500 with a 15 Ah battery.
Reactions: -Bucks-
Alan Quay
2,351
1,076
Devon
How do you suggest they fit a cut out switch?
Reactions: -Bucks-
5,786
A button on the handlebars? Modern kits don't need cut out switches.
Reactions: -Bucks-
-Bucks-
57
Looking at the conversion kits, I think it will be a bit beyond me! so buying the full e-bike is going to have to be the route we go also just noticed that this Carrera Crossfire-E seems to be a road bike so don't think that is going to be the most suitable
Alan Quay
2,351
1,076
Devon
You will need something with a lot of torque, but I'm guessing top speed is less of a concern?
Reactions: -Bucks-
6,492
Reactions: -Bucks-
6,492
Reactions: -Bucks-
trex
7,703
2,671
Reactions: -Bucks-
Alan Quay
2,351
1,076
Devon
Any recommendations for any with a lot of torque Alan?
It does make me think that a crank drive would be suitable, assuming that you are happy with the way the gear changes work.
Something like the Woosh Sant-and CD .
Failing that, something with a BPM hub motor.
Edit: Crossed with Trex. He always recommends a Woosh. In this case he's got a point!
While the KTM's and Haibikes will do the job, somehow they just don't fit with my (perhaps inaccurate) view of what you are looking for.
Reactions: -Bucks- and trex
trex
7,703
2,671
the OP's budget is £1,000.
For that sort of budget, woosh bikes are usually unbeatable.
Alan Quay
2,351
1,076
Devon
If you are riding a bike on your own, with no throttle that's one thing. You can always screech to a halt, throw it the ground and run away.
If you are towing a vulnerable person behind, likely using a throttle, it's a different matter.
Reactions: -Bucks-
-Bucks-
57
THANKS For all the info up to now guys it's getting a bit mind boggling now!
Just to clarify it is mainly for off road use like cycling round woodlands & countryside tracks usually with quite a few hills, our daughter who I would be towing is 13 so is a decent weight to tow now & is only going to get heavier, budget £1000 - £1500
6,492
Reactions: -Bucks-
trex
7,703
2,671
SW, granted that hub motors are not made for off-roading but I think the BPM torque will obliterate any Bosch motor, even the CX. Also, for towing a trailer, you can't beat the convenience of a full throttle.
