Dropbar Road Bike Conversions
Rickidoodah
23
53
My Norco frame is solid no thin ali.
For any one needing to tighten or fit new ones you will need a M5 bolt, a M6 nut or bigger and a washer.
Place the washer against the riv nut then the M6 nut then pass the M5 bolt through them and thread in to the riv nut, hold the M6 nut with a spanner and use an allen key to tighten the bolt which will compress the riv nut you will feel it tightening as you wind the allen key around.
Did you use stainless or alu riv nuts?
