Trex....I really must get used to ignoring your postings but sometimes you come out with such garbage it is hard not to respond.
A THROTTLE MAKES ABSOLUTELY NO DIFFERENCE TO THE MAXIMUM OUTPUT OF ANY ELECTRIC BIKE>
The throttle is purely another means of tapping into the power available,if you have a speed sensor bike and set it on PAS level 5 and turn the pedals you will get maximum power,if you then operate the throttle the bike will offer no more power than the max available-you dont need to be an engineer,commonsense tells you that!!!!!
If the throttle is wired in such a way as to always deliver max power and you set the display on a lower PAS setting then the throttle will give more power but only to PAS level 5.
The only advantage of a throttle is that you can tap into the power without turning the pedals,allowing you to use the bike as a mini moped,being lazy if you like!!!
And your final quote 'if you are unfit get a throttle',surely if you are not fit the last thing you want is a throttle,that is a sure way of staying unfit and reducing the range of the bike drastically.
European bikes with speed sensors(note not torque sensors)deliver full power provided that you set it on the max pas setting,whatever that control may be,could be eco-turbo or 1-5,its the same effect.
All my bikes are Chinese,none of them could ever experience a 900 per cent lift when operating the throttle....9 times....that would suggest that the PAS setting was only delivering 10% of the available power,ridiculous!!
I have ridden many German electric bikes from Scott,Cannondale,KTM,Kalkhoff.....they are all well built bikes,that is why they cost £2k upwards,there is no way that a Woosh chinese bike will deliver 3.6 times(900 divided by 250) more power than say a KTM-Panasonic hub bike just because the Woosh has a throttle.
WHAT WORRIES ME IS THAT YOU SAY THESE THINGS WITH SO MUCH CONVICTION THAT PEOPLE MAY ACTUALLY START TO BELIEVE YOU.
KudosDave
