DIY EBIKE
danielrlee
1,394
723
Westbury, Wiltshire
torquetech.co.uk
For a low powered bike, a geared motor makes sense. Once you want to raise power into the multi kW range however, a direct drive is the only way to go if you require any kind of reliability.
5,786
Direct drive motors are the only way if you want regen braking, but realistically there is no point having regen braking (subject of another blog post)
Unless you live in the Alps or other mountainous region of course where saving brake linings and pads is the point. The electricity recovered being a byproduct.
Reactions: LeighPing
chris_n
737
441
63
Niedeau, Austria
Regeneration would certainly make the wife feel more comfortable in the Alps, riding downhill with the brakes hard on for 6 or 7km is way outside of her comfort zone.
Swytch Bike
154
68
35
Yes that's a very good point
Also - if you're cycling in the Alps you're likely to be covering more than 440m of height, which is the required height we worked out you need to be climbing to make regen braking worthwhile on the average ebike.
Check out this blog post for the argument (and some nice pictures):
http://www.pandaebikes.com/regen-braking-ebikes-worth/
