Disk brakes
VisionOn
7
Herts
I dont think tis has been asked before appologies if it has (just point me at it). Is there a special tool needed to remove Tektro disks (because my 4 mm allen key wont fit). If so whats it called. Please see atachd photo.
3,142
Yes, they're Torx screws, so you need the right size Torx driver or bit for them. I can't remember the size, but I think might be T25. It's standard for bike brakes, so you can find it on any cycling website, or, better still, get a set because they're useful for other things.
Reactions: VisionOn
8,533
Imv Torx screws are much better though as Allen keys can round off on the ends.
matthewslack
1,854
1,341
Confusing when first encountered, but very common nowadays. The driver bits or torx drivers are readily available from "all mainstream tool suppliers".... famous last words!
Reactions: VisionOn
jokskot
159
47
76
Another plus for Torx is the more limited range of sizes compared with Allen keys, where I almost never pick the correct size until the second or third attempt.
