Also interested to know, has anyone had any luck?Hello Urgi,
Any luck with modifying the speed signal from the rear wheel hub? I would like to raise assist limit of E-ST 500...
Thanks in advance
Thanks in advance
Nem lehetséges, tudtommal csak a rockrider támogatja ezt a funkciót ...tud nekem valaki segíteni? Van egy 500e -es folyópartom, és szeretném kicserélni a kereket 27,5 -ről 24 -reView attachment 43509
Hello, my keys were attached to handlebars.HI and thanks for this thread. Daft question to start but I've just bought this bike. Should there be a key for the battery. I don't seem to have one and can't find a basic 'what is in the box' to check. Thanks
Thanks so much. I had another search around the bike and they were wired above the rear wheel! Couldn't work out why they weren't in the box with the battery Hello, my keys were attached to handlebars.
Just keep and record these printed numbers on the back of this display, it's necessary when you need a replacement.Hello,
I have Riverside 500 E with Hyena controler
what are the differences between:
- the release 1 and 2 for the motor
- screen v1 and V2,
- controller 1 and 2
what is the benefits to upgrade from V1 (screen and controller) to the V2 version?
No, I didn't cut any wires. Just unscrewed the connections. It was how you see it. You think the sensor then.Ooh, I think you will have trouble finding a replacement on eBay. It could be a DU B250 in a different case made specifically for OEMs like Decathlon.
If it works OK in walking mode you could have a problem with the pedal assist sensor and the controller could be ok.
Although your photograph shows the blue phase wire has been cut. Did you cut it to remove the controller?
Is that the sensor I might need? On the controller there's a connection that looks like that might plug into. As there was nothing plugged into that.No, I didn't cut any wires. Just unscrewed the connections. It was how you see it. You think the sensor then.
