Daimler Mercedes Designer Smart eBike - pure power
Status
Not open for further replies.
6,509
if you was smart you would of never bought it in the first place pmsl.
if you want a so called designer bike that no one will have then get one of these.
the brakes and discs are shite so needs changing so does the front fork and rear shock handle bars stem seat post and saddle rear cassette mech and shifters and throw nyon in the bin.
total cost £15800 :)
Smart eBiker
404
123
73
Just spent that on a service for my boat so can't afford it at the moment :rolleyes:
Anyway having great fun on my Daimler Mercedes Designer Smart eBike, I have a motorbike on my boat but have taken the cycle as well so have choices of transport when I arrive at marinas ;)
Reactions: Crockers
Gubbins
Goodbye..
Reactions: soundwave
6,509
just because its the most expensive dont mean its the best and has the best parts thus why no one in there right mind will buy that bike.
it just dont add up part wise for the 13k rrp tho i bet martin would lick ur ass crack if you bought one from him.:p
IR772
931
1,044
Leominster
Get some tissues ready because this will make you dribble :)
Daimler Mercedes Designer Smart eBike spec:
TOTAL WEIGHT:
57.5 lbs ( 26.08 kg )
BATTERY WEIGHT:
7.3 lbs ( 3.31 kg )
MOTOR WEIGHT:
10 lbs ( 4.53 kg )
FRAME TYPES:
High-Step
GEOMETRY MEASUREMENTS:
Dimensions: Width 75.5 cm, Length 173.5 cm, Height 99 cm
FRAME MATERIAL:
Aluminum Alloy
FRAME COLORS:
White with Green Accents, Gray with Orange Accents
FRAME FORK DETAILS:
Standard Rigid or Optional Suspension
ATTACHMENT POINTS:
Rear Rack Bosses, Fender Bosses
GEARING DETAILS:
3 Speed 1x3 SRAM I-Motion Internally Geared Hub Inside the BionX Motor
SHIFTER DETAILS:
Grip Twist on Right Bar
PEDALS:
Ergon PC2 Ergonomic Platform
HEADSET:
Cane Creek
HANDLEBAR:
Mid Rise
BRAKE DETAILS:
Magura MT4 Hydraulic Disc with 180 mm Rotors, Right Lever Activate Recuperation (Regenerative Braking)
GRIPS:
Ergon GP1 Ergonomic with Lockers, Matching Color
SADDLE:
Smart Design, Matching Color
RIMS:
Mid-Dish
TIRE BRAND:
Continental EcoContact Plus, 26" x 1.75"
WHEEL SIZES:
26 in ( 66.04 cm )
TIRE DETAILS:
Reflective Sidewalls
TUBE DETAILS:
Presta Valves
ACCESSORIES:
Single Side Kickstand, Front and Rear Fenders, LED Lights with Daytime Running Lamp Function, USB Charger Built Into Base of Front Light Module, Matching Bell on Left Bar, Optional Rear Cargo Rack, Optional Matching Panniers, Optional Matching Rider Jacket, Optional Mounting Bracket and ANT+ Wireless Dongle for Smart Phone Use (Fits 3.5" to 4.3" Screens with Vertical or Horizontal Mounting)
OTHER:
Lockable Removable Battery Pack, Maximum Load 250 lbs, Gates Carbon Belt Drive 118T (20 Tooth or 24 Tooth Chain Ring Available), Deep Sleep Battery Protection (Cuts Battery Draw After Two Months of Inactivity)
Electronic Details
MOTOR BRAND:
BionX
MOTOR TYPE:
Rear-Mounted Gearless Direct Drive Hub
Learn more about Ebike motors
MOTOR NOMINAL OUTPUT:
350 watts (250 w in Europe)
MOTOR TORQUE:
35 Newton meters
BATTERY VOLTAGE:
48 volts
BATTERY AMP HOURS:
8.8 ah
BATTERY WATT HOURS:
422.4 wh
BATTERY CHEMISTRY:
Lithium Manganese Cobalt
CHARGE TIME:
5 hours
ESTIMATED MIN RANGE:
40 miles ( 64 km )
ESTIMATED MAX RANGE:
60 miles ( 97 km )
DISPLAY TYPE:
Removable Backlit Monochrome LCD
READOUTS:
Speed, Odometer, Battery Level, Clock, Average Speed, Assist Level (1-4), Regen Level (1-4)
DISPLAY ACCESSORIES:
Free Smart Phone App for iOS or Android (Map, Speed, Altitude, Calories) (To get the app on an iOS device just search the iTunes app store for "Smart Ebike" and you will see one from Mercedes-Benz Accessories GmbH)
DRIVE MODE:
Torque Sensing Pedal Assist
TOP SPEED:
20 mph ( 32 kph ) (15.5 mph in Europe)
Is that not just a £600 Chinese rear hub
Wisper Bikes
6,282
2,252
69
Sevenoaks Kent
OK how about £500 for my hardly used Daimler Mercedes Designer Smart EBike? No one seems to want it for £600!! :(:(:(
Maybe it's because it's got some dirt on one if the pedals? What to do? o_O
nemesis
521
343
Nobody will believe you without video evidence,lets see it with the bike onboard.
Hmmm! At nearly 30kg, it could make a reasonable anchor for his boat for only £500, but I think this designer one is even better because it's even more overpriced for what it is:
https://www.direct-chandlery.com/partnumber.asp?pnid=393601&source=googlebase&utm_source=googlebase&utm_medium=cpc&gclid=Cj0KEQjw9vi-BRCx1_GZgN7N4voBEiQAaACKVnNvj96g0mZDmBTQkfnFGHgFFYM2gr0dpFzSsB6IixwaApNE8P8HAQ
Status
