To me, the standard firmware seems to be pretty good. What do you want to improve?Has anyone mucked about with custom firmware? Any pitfalls to avoid? Is it a daft idea?
what exactly? have you set your throttle as a power over-ride with P4=1 and C4=3?Ay a push changing the assist output percentages might be useful.
All working correctly. Throttle override is set up like that with P4 at 1 and C4 at 3.what exactly? have you set your throttle as a power over-ride with P4=1 and C4=3?
Can you explain point 2 again in a simple way for thicko? I can't make any sense from it. My C5 is on 10, and it never changes.You know about the custom firmware project on Endless Sphere? It went on for a while, but is no longer supported.
My wish list for KT firmware would be
1. Input wheel diameter in mm, not presets.
2. Keep a default C5 of 10 on assist level 4 always, Then you don't lose max current.
However, if this were available in custom firmware, it's not worth the headaches to install. The KT works great. Why complicate or break it,
