Sorry for the multiple posts ... it's the 4 image limit that's to blame !
Switches are on the opposite side of the box to the cable entry and battery charging socket :
The switches are IP65 waterproof, but as they're both DPDT, each in use for only SPST I've encased the unused pins in Sugru and reinforced the internal proofing so there should be no shorting. Top switch is master on/off linked to the soft start FET switch. Cycle Analyst backlight comes on when the bike is turned on and reminds you to switch off when finished riding.
The accessories are all isolated via the bottom switch. This is only there to conserve battery but on a long ride in daylight it might come in handy. Otherwise it can be left on as the master switch cuts supply at the battery. When the secondary switch is turned on it opens supply to :
Handlebar light/horn switch feeding :
- CREE T6 front light and Magicshine MJ-818 rear light on lights on low beam (running on 9V)
- 36V 3-LED light and 24V 9-LED master headlight (if plugged in) on high beam (either/both come on together with above when plugged in)
- 36V horn (112dB)
Plus
- 12V marine cigarette charging socket (compatible with USB charger insert)
- 12V Hardwire mobile phone charger fitting waterproof tough case - used with Samsung Galaxy SIII for GPS / SatNav etc. but can swap out for cases / cables for any other phone the manufacturer supports like iPhones etc.
I've used Magicshine-style connector cables internally in the box, they're easily accessible when you remove the panel and have a bunch of spare extension leads so it's easy to swap out the lights connected to the 9V supply or even plug in a Y-connecter cable to run two front lights plus a rear light off that.
Haven't yet worked out how to get my camera to take night shots of bikes with lights on (!) but proof of the pudding :
All 3 front lights on (headlight fitted just for testing - I'd never use it in a big town, just the 36V light is enough for high beam !)
The single MJ-818 is more than plenty at the rear but there's space to mount another on the left and a slot in the middle for a regular battery-powered back-up Smart Lunar 2 x 1/2 watt for emergencies.
The biggest surprise really in the wiring was the amount of spare cabling that's integral to the Cycle Analyst LCD display. I've a storage area between my handlebars and the Rixen/Kaul handlebar bag extender mount that I modded to mount my big headlight which accommodates it all bundled up. Basically it's a whole bunch of comms and data cabling that's integral to the CA display and isn't really needed (by me). My phone charger lead has a load of excess too - with a nice sewn on velcro strap. So I've just wrapped the velcro strap round it all and popped a cable tie round the adaptor to hold it all in place.
I've discovered there's one rule of wiring that comes with stuff you buy. If you need a long cable it's too short and you have to extend it. And if you need a short one you have feet of excess - especially on fully waterproofed stuff you really don't want to start chopping up ! Else you have to shorten it... which I did with many things. Literally all a*se about face ... including the battery wires and and all the Cycle Analyst stuff. The only thing which was the right length 'out of the box' was the unfeasibly expensive light/horn switch that's dirt bike spec. I made all the other wiring to measure so in a way that was easier.
Riding the bike in finished configuration is helping me conquer my fear of that f****** throttle a bit too - have been just so many tired mistakes with all the stopping / starting the build, with it wheelying / taking off on me (or not functioning during the building / testing for various reasons before getting the switches properly sorted and 'user-friendly', usually not putting on the stand ! ) that I literally get pangs of adrenaline and dread at the thought of it every time I sit on the bike or hold the handlebars.
Perhaps this is at the root of something ! It wouldn't be so bad but that motor's not one you want to have to tame too often standing beside the bike with the handlebars making a bid for the moon. It's a shock at the best of times. My multi-level anti-idiot/scatterbrain isolator systems work and are definitely needed ... by me !!! So yes, everything now works well enough. For me.
Riding the bike with everything working at the push of a button or two, lights all sorted at the flick of a switch with no little batteries to fanny about with, phone charging as I ride and some nice music on, horn if I need it, backlit LCD with all I really need to know and a cruise throttle if I'm feeling brave .. well .. I have to confess ... with it all how it should be (and as far as I could get it - where it should be) was much nicer than I was braced for. I even smiled (OK I nearly screamed with joy and relief). It's an incredible piece of work and I don't say that to myself very often.
Guess I just have to get used to swapping between my crank drive and this bike - because they are such very different animals in every way. Riding with a throttle is so completely different and I've had much less practice at it. I'll have a tough job getting sweaty on this one - unless I turn off the motor completely. In a way it's nice to have both. I've tried - again and again - but it's impossible to compare them. Both are impressive things in their different ways. If I was fit enough to manage all my terrain easily with the Kalkhoff I'd have been happy with that. But this has plugged a need on very long very steep hills that nothing less would have plugged... and the Kalkhoff just couldn't stretch to... not to mention I need a bike in 2 different places.
Anyway, once I've cleared the cyclical backlog of other commitments that's built up each time I've made a bid to finish the build over the last 4 months I am dearly looking forward .. to some sleep at night
. Just pray the bike stays working OK. I've honestly pretty much given all I have to give to it in every possible way. I look at it working and still can't believe I made that... with a mechanical bail-out from d8veh when I f***** up the lead and endless teaching to boot from a number on here lol ! It's blown my mind actually.
