Could this be a lead-acid battery?
3,993
Thank you. I suppose the Philyons are beyond recall? Maybe 6 years since they were last used. Out of the single one is coming 0.3volts.
Those cells will even show 4.2V when knackered, but at 0.3V, you can bin the whole lot, except maybe keep the key-switch.
Reactions: KirstinS
30,613
Indeed, they were never long lived. None of the three I had reached two years, usually failing far short of that.
Reactions: KirstinS
KirstinS
3,224
899
Brighton
I can attest to this as, despite being told by vfr, I still spent ages reviving all cells in a similar pack back to 4.2v slowy and painfully. Then reassembled pack, hooked it up and drove off. About 10 yards before 42v became about 15v. I think the case is in the shed still
rogermunns
20
Thanks for all your help. I'm now waiting for a new 36V Samsung cells pack. But, because the sender (in Poland) uses GLS Delivery, I might be lucky and get it before Christmas!.
8,533
GLS are usually quite good, I select the GLS option when using Nkon and arrives in 4 days.
