Could some kindly take some measurements of a tongsheng and bafang mid drive?
matthewslack
2,382
1,599
This arrived today:
This is how it looks:
It would need about 6mm of spacer on the chain side, which means not enough thread on the clamp nut side. I could shave 5mm off the bottom bracket face to improve that.
I think the options are:
A. Shave a mm or two off the chainstay and a mm off the motor casing and a few mm off the bottom bracket opposite face.
B. Cut 5mm off the chainstay and weld a reenforcement on the back of it.
C. Bafang HD 1000w
I’m going to investigate what the chainline would be with A. Can you get an offset/dished chain ring for the tongsheng? 40 teeth or less.
The cardboard model from Matthews measurements was pretty accurate.
I think you are so close that A is worth a go. The nut plus the support bracket on the non-drive side is exactly 10mm total thickness, with no added washers. It looks like you might have 4 already. There is almost enough BB that end, especially if you eat into the weld a little. The drive side can spare a bit, but being aluminium, don't go too far, and keep finished surfaces smooth to reduce likelihood of fatigue cracking.
mr_ed
116
18
btw if anyone reads this thread and would find the broken tongsheng casing useful for a similar purpose get in touch and I'm sure we can sort something out.
