I've never heard of that being an issue before. What do you mean? It looks like a standard Shimano SLX Hollowtech bottom bracket to me. The only problem I can see is to install a battery.Only issue is width between chainrings.
It shouldn't foul the cranks. I have one with Shimano SLX Hollotech cranks and there's plenty of clearance. A Hailong type battery is 90mm wixe. You can check how much clearance you have. with a ruler.Yeah. The battery fits well using the mounting kit on the frame under the triangle, but the width of the battery fouls the cranks, not the chainrings, sorry.
