Conversion kit ordered
Alan Quay
2,351
1,076
Devon
Yip downtube battery ordered,I was wondering about that very thing but reckoned it must be ok cause haven't seen it mentioned before, shouldn't be a problem though av got access to the proper tools in my work
Sometimes the existing holes are in the right place, and will be OK for light (road) use. In my experience, an extra one is a good idea.
Sent from my HTC One_M8 using Tapatalk
Reactions: LeighPing
footpump
713
75
76
I have the ebc rear hub kit fitted to specialised sirrus elite but used a bigger controller bag (there is a lot of wiring)
as regards downtube batteries its asking a lot for 2 5mm bolts to hold a 7lbs battery in place so I use cable ties in addition to the bottle cage mounts.
I also use cable ties around the frame and battery, (I do not remove battery to charge it)
some people have broken battery mounting plates after hitting potholes etc.
I am at present installing a ebc 250 watt crank drive, but it is not all plain sailing, there is simply no room between installed moter and frame to run the rear deralier cable in its original position (under bottom bracket)
so ive got to somehow re route the cable
ps screwfix sell long /strong cable ties 500mm long if I am correct
Tabs
279
132
65
Scotland
Kit arrived today and yes am thinking an extra something to secure the battery is a good idea, I ordered a 13amp downtube battery but the sticker on it says 36v 11000mAh ,is that right or should it be 13v 13000mAh? Here's a picture DSC_0156.JPG
D8ve
2,142
1,294
Bristol
36volt 13000mah is what I would expect.
Sale of goods , not as described.
Please send correct battery and collect wrong one or refund
Alan Quay
2,351
1,076
Devon
Rivnuts are neater & stronger.
Tabs
279
132
65
Scotland
That's what I was thinking, strange though only 11amp battery I see on their site is a rack battery all downtube battery's are 13amp? Email tomorrow morning!
D8ve
2,142
1,294
Bristol
Looking closer at the English,
, desposed to fire?
Alkalesecent liquids?
Translation is not top grade. Is the compliance that good?
Right sticker wrong battery?
footpump
713
75
76
I have just looked at my ebc battery nothing on mine to give the ah rating but I have asked and been told 13ah
I have just weighed the ebc one=6.37 lbs
my bottle 10.4= 5.50 lbs
have no idea if that's relevant
I would give them a ring they are very helpfull
Tabs
279
132
65
Scotland
Strange that your battery has no markings on it,somebody might know how to check it,it might be as easy as sticking a multi meter on it?
Alan Quay
2,351
1,076
Devon
No, the only way to be sure is a full discharge test. You can take it apart and look at the cells, but that's only as good as what's printed on them.
Discharge test can be done on the bench, or on the bike with a watt meter.
Tabs
279
132
65
Scotland
Nothing is ever straight forward!
Alan Quay
2,351
1,076
Devon
One of these, connect between battery and controller, ride around a bit and it will let you know how much has been used.
Unfortunately, when the battery dies, so does the power supply to the device, so all memory is lost. Either power separately or check regularly.
http://www.ebay.co.uk/itm/252242300442
When I test capacity I do so on the bench, with a fairly constant load.
