This is a dream thread for me as I have had on my mind the conversion of my dahon D7 vitesse for quite a long time..I have started a thread of my own about it a while ago but I have lost hope in it as the prices were quite high and I didn't think I could afford it at that time.
Jhruk you suggested the 83mm version (nice input for the careless people like me). At the
bmsbattery Q85 36V Front Driving V-Brake E-bike Kit site there is a tab under DATA Sheet that says “cable location Left”. Does that mean that the cable comes from the left side of the motor (the same side that the folder Magnet is?)
I took some pictures of my Dahon D7 and as you can see the space there is really tight.. Was that an issue?
The cable does exit the motor on the left. It doesn’t affect the folding on mine & seems preferable as it protects the cable from damage when folded. See photo:
I see in you photos that is the case. But is seems like your folded steering wheel goes further down than mine does(?).
Photos:
My Impulse has a quick release adjustable telescopic handlepost & I adjust this before folding. I’ve marked the positions on the post with an indelible pen. Looks like your D7 is adjustable as well.?
Another thing that concerns me is the waterproof ability of the bike.. Hows that going for yours?
As I only use the bike for leisure I try to avoid wet weather & therefore didn’t worry too much about waterproofing. It’s really down to how you install it. The motor should be the same as any other – some people put a squirt of silicone sealant into the axle where the wires come out. The ‘waterproof’ motor cable connector at least looks as if it might live up to its claim. The rest would be trying to keep the connectors to the controller as dry as possible & maybe enclosing the controller.
I really admire the work you ve done with your impulse. Seems really neat, what I hope to achieve.
Thank you – it was really easy with the kit & only took an afternoon. Just make sure you’ve got plenty of cable ties handy!
How much does it weight and hows the mobility?
I haven’t weighed the bike but the claimed weight for the motor is 1.9kg and allowing 0.5kg for the controller, wiring etc would suggest it adds around 2.4kg to your existing bike – excluding your chosen battery of course. At present I use mine with a fairly heavy 15Ah Ping battery, which I switch between other bikes, and I now use an
Altura rack bag to contain it. This comes with a ‘landing strip’ which is permanently attached to the rack & allows for quick & easy removal of the bag - which then becomes a shoulder bag. This makes the bike much easier to handle if you have to carry it far or put it in the boot of a car - it’s also claimed to be waterproof!
So far no real problems & I’m still very happy with it.
