Conversion kit for a trike?
reynoldsc07
Jul 17, 2013
Wrexham
B843EF1D-BD6D-4ABC-BA89-B2ECF16EE4FC.jpeg The Mission trike has a 16” front wheel, and V brake with 21 speed gearing. Is there a suitable hub based motor with throttle control out there? Any advice gratefully accepted
8,844
The best option may be a BBS01B crank drive if the bottom bracket housing is a standard 34mm dia.
You would loose the 3 x front rings but will have full throttle you can use, though controllers can be a bit flaky whether they are reprogrammed or not.
Another option is a GSM mid drive without integrated controller and use a separate KT controller and LCD3 with full throttle enablement or set it legal for throttle once pedals have turned (1/8 - 1/4 turn is all that is needed).
