Computers and stuff...
6,733
says it will fkn fall down in 24 years and the fkn retards put that inverter in the attic when they knew it could spread to next door or was that the plan to burn them all to the floor ;)
3.3.7 Loft Space – Party Wall (a) The risk of fire and/or smoke to spread across the party wall should be eliminated. The risk of fire is generally quite small, but when a fire occurs the consequences can be serious. We recommend that where the risk of spread is higher, ie where large gaps around purlins and at ridge level are identified, remedial works should be undertaken immediately. Stroud District Council should adopt a policy of inspecting for this defect at all changes of tenancy, and carrying out works to seal any gaps at that time. Whenever works are undertaken to a property there should be an inspection and remedial work undertaken if necessary.
3.3.4 Remaining Life (a) No change since 2003, the retained PRC components should still have a remaining life of 30 years from now.
3.0 Airey 3.3 Conclusions & Recommendations Housing Committee 27 March 2018
6,733
3,411
You're tarting up the place and planning for the future, that's typical nest building behaviour for Rolex Chick or Transformers Chick. Have you noticed yourself brushing your teeth more often?
3,411
3,416
Was reading your post and "remaining life" leaped out. If rolex chick is unresponsive there's always option of writing next big existential novel. Title like "remaining life" will knock the socks of Camus's The Outsider. Only snag is everyone seem to be in blanket denial and so ******* preoccupied with killing each other that they may not be able to think about the human condition.
6,733
6,733
6,733
6,733
led strip 10w per meter :eek:
6,733
3,411
3,416
A sure sign of the Rolex being far too big, or use of a date rape drug.
Do Arab chicks like pork swords?
Speaking of shafting the repressed and almost unconscious, has anyone watched any questions/answers? Is it just me or is it odd that there's a "technical problem" that prevent open discussion on aa after sukak tries to set the limits of what we're allowed to discuss (or allowed to protest about)? And Maggie starmer runs around like a headless expedient chicken looking for any political agenda that will maintain the status quo.
6,733
give um a ring :eek:
6,733
will have about ten plus led magic home controllers installed when done :cool:
3,411
6,733
i think we should house all the immigrants in one large city build a wall around it and blow the lot to fkn bits with missiles :D
just make sure u paint them green ;)
6,733
what i think will be a good idea is a ar 15s pointed to every one in the house of bs and locked in to there seat and let the public vote on line.
:p
