Computers and stuff...
3,376
6,722
oh well me gas boiler is trying to explode :rolleyes:
3,376
Is it really noisy? Might need extra water in the system, check the water pressure guage. There's a tap underneath probably somewhere. Too high water pressure will trigger a shutdown or something, unless you bleed some water out of a radiator. On the older style rotary pressure guages, there's a marker on the dial indicating what water pressure should be. Could save you a callout, or could explode your house, your choice what will you do WHAT WILL YOU DO?!!??
6,722
build a robot#
car parts ;)
3,376
One of these days a fellow Transformers model enthusiast is going to surprise you by uploading photos of his, and you'll need a sedative and a lie down to recover from the shock. ;)
6,722
Reactions: guerney
3,376
Useful having that bullet - the cops will never take you alive.
6,722
20240117_042210[1].jpg ;)
scraphook had to die
3,400
afraid i don't have transformers, but i do have a cunning plan - most gas boilers have electric kettle type element as backup, and octopus offer an ev specific energy plan that charge 7.5p per kwh at night between 1230 and 630. switch energy plans and switch the boiler on a timer to electric at night rather than spending thousands on a new boiler or a heat pump (have colleague who has one and his energy bills are as high as with gas). its not glamorous, but ive done this and its saved quite a few quid during a cost of living crisis.
6,722
was a blocked pipe under the sink that needed draining :rolleyes:
6,722
thought that box was a bit to big :oops: fkn thing wont even fit on the shelf :rolleyes:
6,722
:p
6,722
fkn usb c cables dont fkn fit :eek:
3,376
They're designed to boost sales of sandpaper and Dremels.
6,722
need a dremal to make that fit in that hole :oops: its a psu for the cctv cam so just used another phone charger.
6,722
6,722
game over :rolleyes:
6,722
:p
6,722
