Computers and stuff...
6,732
54099
got that for 16 quid inc pat just incase.
6,732
fkn solar clamps only want the live cable as wont work if neutral or earth in there so now need a electrician as if i fook it up its my fault so cant touch it
6,732
3 firmware updates later and 422w is 11.93 per hr on edf 61.09 standing charge and 28.27 per kw @ 98p all ready :p
6,732
and im still not dead :p
6,732
i need more power i killed all the solar panels as now wont power up :D
6,732
all leds on elster box dead guy said it must need a reset as password locked and no fooker has it so wont get the feed in tariff until sorted :rolleyes:
6,732
it is working tho lol :p
6,732
massive spike was shower
6,732
6,732
oh crap there a bit tall not sure it will fit back in its hole lol
Reactions: guerney
3,410
Drill three holes out of the case?
6,732
its not a case but just test fitted it and will just fit :p
3,410
There used to be easy to use programmable macros for setting focus to controls and send keypresses to browser based interfaces, but if this is an app and something similar isn't available, you can probably get a peopleperhour guy to write a program to try every combination.
6,732
it is just the bit that sends the signal to the council or lcx but the inverter is working so up to them to sort it as only turned it off lol
3,410
Many years ago, I used macros to win a "first come first served" council house bid for a friend - the website was open for bidding at 12.00am, I started the macros at 11.59pm and won. Then someone noticed the many very rapid bids and changed the website.
6,732
down to 84w buy 7 it will be noting from the panels :(
6,732
not got round to solder them in yet, but that other psu will be here next week so can slap that in there for now but as long as i got both the 19v rails back it should work.
might be some bargains to be had if it is this easy to fix it as i got all 3 at the same time.
it is just insane no one will even try to fix this stuff anymore its replace the hole psu or bin job, boils my **** esp when i can pay them to do it :rolleyes:
6,732
:p
Reactions: guerney
3,410
Cool! Connect the PC/iJesus, test at max res with full colour and 100% brightness.
