Complete Wheel set for 29er
IR772
931
1,044
Leominster
I would like another set of wheels to have a different tyre selection, it seems a lot easier to change wheels than tyres.
Is it as simple as buy the bits and put them together ? I want to drop in and out different wheels with everything fitted.
Not looking for a Rolls Royce, Mondeo will do me fine, just want good quality and works. Are these the right size bits and is it straight forward to put together.
From Chain reaction does this look right for my Sduro 29 SL, will use tubes.
Open to advice as I know nothing about it at all. Preference is to buy all from one supplier for ease.
Wheels
http://www.chainreactioncycles.com/kore-xcd-mtb-wheelset-2016/rp-prod109565
Brake disc 180mm
http://www.chainreactioncycles.com/shimano-xt-rt76-6-bolt-disc-rotor/rp-prod39007
Cassette
http://www.chainreactioncycles.com/shimano-deore-hg50-10-speed-mtb-cassette/rp-prod124932
6,486
IR772
931
1,044
Leominster
When you say bottom end you mean cheap not some technical description ?
A sealed bearing set will cost and an example might be ?
6,486
IR772
931
1,044
Leominster
Still all good in the price range happy to go for that.
Any thing else tool wise to fit the cassette ?
6,486
you will need a chin whip to remove it thats all you need imo.
my cb wheels when new in 2014 was £500 each.
6,486
yeah you might as well as you will have to take it off one day when it is worn out.
IR772
931
1,044
Leominster
Including a set of elbow protectors that is £ 370, so a bargain compared to just one of yours. I did not want the best, just good, which is fine for me.
Thank you for your advice, I will put the pictures up when I have built them. Or bring them down for you to put right if it all goes Pete Tong.
6,486
IR772
931
1,044
Leominster
Those cobalt wheels look good and they are eBike rated.
Also a very complementary reviewer said:
"Excelente roda, me enviaram com todos os acessórios para usar em vários tamanhos de suspensão, enviaram também os bicos para tubeless, tudo perfeito, muito bem embalado também"
Who could argue with that ?
Reactions: chris130256
6,486
there tubeless ready as well no rim tape needed ;)
6,486
you will need some valves if you do not sure if they come with any or not?
Pinoy-E-MTBer
25
42
52
Bay Area, Ca
Since you're buying a new wheelset,tires,etc...You want to look into a 27+ setup. I'm sure you'll have plenty of clearance with your 29er.
Definitely go tubeless to minimize the possibility of flats too.
6,486
err they come with both end caps for axle or qr.
Related Articles
