Comfort on long rides
Peter.Bridge
1,866
828
Just did a similar route, 1hr 45 min ride, on two of my bikes, boardman 29er with mid drive and an old scott genius MC40 hub drive with 26" wheels. When I came back, I noticed I was a lot more "achey" after the (much newer) boardman ride, with arms , shoulders and back aching a bit. When I came back after riding the scott, I felt great. Maybe partly due to full suss (although these rides were on roads) but also the wheelbase is significantly shorter. Is there some explanation ?
2,858
The arrangement of the bars is likely to make for a lot of the difference.
Distance from saddle to the bars (by bars I mean the part of the bars you actually use).
Height of the bars relative to saddle.
Swept back angle of the bars. (I find most bars are too straight which is good for control and bad for comfort.)
If they are swept back. the drop angle.
4,227
Put some of these bars and one of those curved Aliexpress seats on any MTB and it immediately becomes a bike you can ride all day:
I let a drop-handlebar roadie friend try my Giant Lafree with similar comfort handlebars, since he'd never tried e-assist. When he returned his immediate comment was, "What wonderful handlebars", not a word about assistance!
Waspy
684
283
I agree with the others. It's all about the handlebars. If the longer wheelbase bike is more uncomfortable then you are stretching out further probably to flat, straight handlebars, so more of your weight is falling on your wrists. Pullback bars will shorten that stretch.
Tyre pressures are also worth considering, higher pressures give a harsher ride.
Reactions: Peter.Bridge
2,858
(sorry can't get his image to appear above)
Bar sweep angle is very much personal preference. I've got some very like these from Saneagle post #3 on the front of our tandem and I find them a little too swept back. Waspy's in post 6 look as if they'd be about right for me.
My original almost straight ones were very uncomfortable and well worth replacing. The Saneagle-like replacements are too swept back, but not bad enough I'm changing them again. The original bars on our Raleigh Motus are just right for me.
Try sitting on the saddle with your hands forward and find where they don't feel feel twisted.
To adapt to left/right twist get handlebars with a different sweep.
To adapt to up/down twist rotate the handlebars about the stem mount to raise/lower the back edge.
It would be interesting to see photos of OP's bars on his two bikes.
8,843
Agree with every one here , reach and handle bar positioning / bar styl make a heck of a difference to comfort.
My Kona Ute has nice swept back bars with the addition of a Redshift supension bar stem , also the 650b 42c tyres soak up vibrations like suspension does.
If I was 30 years younger this is the bike I would use for touring.
The lidl saddle I have has worn badly and is all taped up so I have a Rockbros to try out.
AndyBike
1,777
767
Sweep is going to have a relation to bar width.
If its narrow bars, say under 700mm, any pronounced sweep is going to twist your wrists in an unnatural way, which will become uncomfy after a while.
Sweep is more a thing for 800/810mm bars.
Reactions: sjpt
Peter.Bridge
1,866
828
Boardman 29er
Scott Genius (26" wheels)
So just tried sitting on both and comparing them side by side
The Scott handlebars (surprisingly to me) were slightly higher and slightly curved towards me
Because the wheelbase was shorter, the center of the handlebars on the Scott was closer to the saddle
The handlebars on the Scott were narrower
The bottom bracket on the Scott was slightly lower resulting in the saddle being slightly lower (when I'm sat on it and the rear suspension is slightly compressed). The pedals are closer to the ground at the bottom of the pedal stroke
All of this means I'm "reaching" more for the handlebars on the Boardman and I'm leaning forward more and more of my weight on my wrists, which probably explains it all
Thanks all for the comments
Reactions: flecc and sjpt
3,411
Cadence
344
253
The Boardman appears to have a longer stem, which will make the reach longer and make the handling different. You could swap the stems over and see how it feels then?
Peter.Bridge
1,866
828
The Bordman bars appear to be on a weird angle, loosen all of the brakes, shifters etc and rotate the bars into a better position.
I was just thinking that - they look like they are pointing downwards, I can rotate them so they are pointing more towards me (They've been like that for 10 years !)
Sturmey
756
394
69
........The Scott handlebars (surprisingly to me) were slightly higher and slightly curved towards me......
........The bottom bracket on the Scott was slightly lower resulting in the saddle being slightly lower (when I'm sat on it and the rear suspension is slightly compressed). The pedals are closer to the ground at the bottom of the pedal stroke
Some people, myself included, find running a smaller wheel at the back makes the bike more comfortable. I did this initially with fitting an ordinary 26 mtb with a rear 24 creating whats sometimes called a'mullet'. Presently I run a Carrera Vengence (27.5) with a 26 rear motor wheel and handlebars raised higher. It lowers the rear and bottom bracket and gives a more relaxed feeling when cycling.
Waspy
684
283
Good point, I forgot about the stem.
Some are long and flat pushing the handlebar even further out.
Mine (made by UNO) has a 35 degree upward tilt.
Loads of different sizes/angles on AliExpress.
Waspy
684
283
I like your thinking. I suppose I will now be browsing Gumtree for 27.5" bikes (which I won't buy of course).
matthewslack
2,595
1,672
The longer the ride, the more specific the feedback your body will give.
It was very clear on my first long trip, 300 miles, 5 days, that two things had to change: general discomfort from shoulders (slightly arthritic, but normally no pain) said 'less weight on bars' which meant raise them, and severe pain in inner edges of wrists said 'change the angle or give up'.
20,000 miles later...
Reactions: sjpt
