Choosing a bike for a tall guy (over 6')
My son is 6'2" tall and is finding that all the electric bikes have smaller frames than that recommended for his height.
Can anyone suggest an electric bike that would be suitable for him? We're looking in the range £1000 to £1500. He will be using it to commute 7 miles to work up and down hills in Oxfordshire.
Edited by fairyhedgehog
  • Replies 53
  • Views 11.4k
I'm 6'4" and a bit (36" inside leg), and am riding a standard large framed Whyte Coniston, which is comfortable for me.
The Wisper 905's were also a comfortable fit.
If you can get the distances between the pedals, seat and hand grips right, the frame size itself gets less important.
Gaz
I'm only 6ft, but because I have truly enormous feet I'm effectively 6"3. I'm most comfortable on a 22/23" mountain bike. So I understand the problem.
While I'm sure there are companies that make them that big they are few and far between.
For this reason, I think it best to find a non powered bike that fits then convert to electric.
Should be easily done for 1k including a new bike (prob a 29er)
Sent from my HTC 10 using Tapatalk
Thanks, Alan. Not sure if we could manage this or not but it's worth thinking about.
It's not as hard as you would think, and there are peeps on here who will help, or even do the job for you.
If you have to pay, £100 seems to be the going rate. Prob still within budget.
At 6ft 2" the lad will only require a standard large frame, not something unusually big.
On eof the advantages of more expensive ebikes is they often come in different frame sizes.
If you can stretch the budget a bit, you might be able to get something like a Cube Bosch powered bike in a large size.
Another point is large bikes are less popular, so a retailer may discount a large stock bike more than a medium which he knows someone will buy.
Edited by RobF
£100 for someone to do it is well within budget, and we have two good local bike shops to choose from. This is definitely something to look into!
On of the advantages of more expensive ebikes is they often come in different frame sizes.
All good points which I shall pass on to my son.
Thank you!
A bike you could consider is the one-size Winora Radius, currently on offer at £1,595 from 50 Cycles.
It has a compact 20" wheel frame designed to appeal to a wide range of riders.
All that really matters in bike sizing is the three points of contact, saddle, pedals and handlebars.
If you can get those in the right place, the metal and rubber in between them doesn't matter.
Your son would need to try the Winora, but it will likely have a very long seat post which means pedals and saddle will be in the right place.
I don't think that model has adjustable handlebars, but they will be set fairly high so will probably be suitable.
In other respects, the Winora is a good quality bicycle for the money, the Yamaha crank drive is one of the best and the bike components should be durable.
http://www.50cycles.com/electric-bikes/winora-bikes/radius_plain.html
Edited by RobF
It has a compact 20" frame designed to appeal to a wide range of riders.
It's definitely in our price range. As you say, the only way to see if he could ride it comfortably is to try it.
Size aside, a commuting bike would normally have mudguards, a rack to carry stuff and lights.
The Winora has none of those, but could have relatively cheaply.
It may be son doesn't need to carry much luggage so could use a rucksack, a clip-on handlebar bag or fit a rear carrier if more capacity is needed.
Modern LED clip-on bike lights are cheap and work a treat.
Mudguards are available for 20" bikes, the frame may have bosses but 'guards can always be fitted somehow..
He'd definitely need mudguards for commuting! I've ridden with and without and I wouldn't like to turn up at work covered in mud!
On a minor point, the Winora has a plastic sleeve which covers three sides of the chain.
A good idea for a commuter in terms of rider cleanliness and reduced chain maintenance.
That's useful.
If you are considering budget Chinese, Kudos is also worth a look.
They have several models which are reasonably well kitted out for commuting.
Dave, who owns the business, is a member on here. Kudos isn't far from you in Kent, and they have a good reputation for service.
Commuting is the hardest use for any bike, and I'm not convinced the budget Chinese bikes are up to it.
Of course, those that sell them will disagree.
I am independent in that I couldn't give a stuff about any bike brand, including the ones I own.
The Chinese bikes tend to suffer from niggly faults, often electrical - dozens of posts on here demonstrate that.
Fixing the faults is usually not difficult, but neither is it instant, which can cause problems when you rely on the bike to get to work.
http://kudoscycles.com/
Regarding reliability. We understand that an electric bike is often essential transport. So, if your new Wisper or Riese and Muller develops a fault covered under warranty during it's warranty period, as long as it has been correctly serviced and maintained, we will send you a loan bike for use whilst your bike is off the road and arrange collection when your bike is fixed. Loan bikes will sent out if we are unable to get your bike back on the road after it has been in our or a dealer's workshop for three days.
Fortunately both Wisper and RM bikes are very reliable. We started this initiative over a year ago. So far we have not had to send a loan bike to anyone.
All the best, David
(We now have 5 test ride centres in Kent)
Buying from a nearby dealer has its advantages.
The manager of my local bike shop prioritises work for customers who need their bike to get to work, and can always put his hand on a second hand bike to use as loaner.
All provided the customer passes the attitude test, which happily most do.
He calls it 'friends and family' service, which also extends to discounts.
I've been going there on and off for more than 20 years, so qualify for that status.
Last time I left a bike for some work they lent me the Brompton demo to ride home on.
Thanks! I have a feeling that's not what we're looking for, though.
Fair enough, so that also rules out woosh and many other direct sellers because quality wise they are all similar.
Wisper is worth a look, still Chinese, but arguably a bit better quality and the bikes are available from dealers.
I tried a Wisper Torque recently and was quite impressed, nice quiet motor, although the bike did rattle a little bit over bumps which a £2,500 ebike wouldn't.
The rattling wasn't that bad and wouldn't bother many riders.
To be fair to Wisper's manager, he agreed with my observation and said Wisper are working on making the bikes feel a bit tighter.
https://amps.bike/product/wisper-905-torque/
Thanks Rob,
The rattle came from the rack, as Claud mentioned, we have now cured the rattle by using bigger bolts and moving the location points.
All the best, David
